Healed, Healed_ AND TempVar are Bytes?
Is the above in the code you are running.Code:DATA @10,0,0 'first hit DATA @12,0,0 DATA @14,0,0 DATA @16,0,0 DATA @18,0,0 DATA @20,0,0
If so, every time the PIC starts those values are written. If this is not the case then...I display the values in the EEPROM and they are those I set at the time I flashed the PIC:
Nope.. DATA is performed at programming time only.![]()
Thank you for your help but this time I could solve the problem:
I was using a routine that displays at the begining of the program the contents of the EEPROM at location 10 to 21 using an index var (hitnr).
Then later in the program I was writing to EEPROM using the index var BUT i forgot to reset the index var to its initial value after using it at the begining of my program so I was thinking I was writing to location 10 while the index var was already at 12. So when restarting the pic, I was displaying values of locations 10 and 11, that were still at 0 so I thought EEPROM write failed somehow. I was at the wrong memory offset...
Stupid error, I should get some sleep
Have a nice day.
ME TOO. I was close.Stupid error, I should get some sleep
Hello xnihilo,
what does your code which makes healed_ into an address location look like ?
