Is there any reference material such as code examples and schematic to accomplish this task. I am looking at the 16 ch 4067, only available in DIP?
HCF4067M013TR 24pins soic
CD74HC4067SM96 24pins ssop
CD74HC4067M 24 pins soic
available at digikey
http://www.digikey.com/scripts/DkSea...S&Cat=31523475
Also, what (dielectric) adhesive can be used to bond to a PCB? Does regular hot glue work?
you can use about everything but no need it. Usualy epoxy glue is used.
I am going to retrofit an existing circuit and enclosure to accommodate 12 IR sensors. Any suggestions as to how to retrofit cables into an enclosure?
can you provide more details on that. what is already exist, etc.
is by any chance you can post any picture ???
regards
