multiplexing IR array into PIC 16C7x
Results 1 to 2 of 2
    Nov 2004
    Calabasas, CA
    Default multiplexing IR array into PIC 16C7x
    Is there any reference material such as code examples and schematic to accomplish this task. I am looking at the 16 ch 4067, only available in DIP? Also, what (dielectric) adhesive can be used to bond to a PCB? Does regular hot glue work?
    I am going to retrofit an existing circuit and enclosure to accommodate 12 IR sensors. Any suggestions as to how to retrofit cables into an enclosure?
    James
    HCF4067M013TR 24pins soic
    CD74HC4067SM96 24pins ssop
    CD74HC4067M 24 pins soic
    available at digikey
    http://www.digikey.com/scripts/DkSea...S&Cat=31523475
    you can use about everything but no need it. Usualy epoxy glue is used.
    can you provide more details on that. what is already exist, etc.
    is by any chance you can post any picture ???
    regards
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 07:09
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  4. transferring word array to another pic
    By garret in forum mel PIC BASIC Pro
    Last Post: - 6th April 2005, 17:00
