Pic12f629-i/p
Results 1 to 7 of 7
Thread: Pic12f629-i/p
    Mar 2008
    Default Pic12f629-i/p
    Is it possible to interface a DS18b20 to a PIC12F629-I/P?
    What I want to do is possible is have 1 ds18B20 as an input and 4 outputs simple transistor switches that go high and or low depending on the temperature of the DS18B20
    Wink
    Hi, Karen
    VCC, VDD + 4 Outputs + 1 input = 7 pins ...
    One pin left for what you want !
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by karenhornby View Post
    Search here for 18B20 brings up over 50 hits...most with code...and the PBP manual says OWIN/OWOUT will work on 12F series PICs, with a couple of notes.
    Mar 2008
    I know the code for the DS18B20 thanks so hopefully wont need any help with that, and hopefully the pic will have enough space for it lol
    What i wasn't sure was if the ds18b20 would "talk" to the pic, still new at all this and learning as I go sorry
    One thing you could help me with if you dont mind me asking questions again
    If I wanted to monitor a range of temp's and enable an output only between 2 temp's i.e. a pin go high only between 30șC and 50șC but as I'm not using an LCD display to display the temp, how would I do that?
    i've done it before using an lcd but I'm not sure if the same works or not when you dont have an lcd connected or displaying the temp
    skimask's Avatar
    skimask Guest
    Use a Red/Green bicolor LED, or maybe continuously flash an led on the output, have it output a series of pulses relating to the actual temperature.
    If you've got an o'scope, you could output a pulse corresponding to the temp (i.e. 50C = 50ms pulse).
    Mar 2008
    Last of my stupid questions for today, can I just tell the led to light when it gets to say 30șC and go off at 50șC?
    skimask's Avatar
    skimask Guest
    Quite frankly, it depends on whether or not you can figure out how to code it that way or not.
    Let me add on to that statement a bit...
    It depends on whether or not you can write the correct code to read the temperature output from a DS18B20 and create a single or pair of IF/THEN statements to either set or reset the port pin that the LED is connected to.
  1. semaphore pic12f629
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 7th November 2008, 13:55
  2. Ultrasound with PIC12F629
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 28th February 2007, 16:22
  3. PIC16f877-20 to a PIC16f877A I/P Disaster
    By andyf in forum mel PIC BASIC Pro
    Last Post: - 21st November 2005, 17:11
  4. PIC12F629, useing all I/O pins
    By Jcee324 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2004, 11:05
  5. PIC12F629 or 8pin
    Last Post: - 27th October 2004, 18:11
