How random is "RANDOM"?
Results 1 to 12 of 12
    Probably you'll have better results if you change the SEED value.
    Default Random function
    I found the RANDOM function to be pretty good for number distribution. I can't find it now but I had PBP generate groups (up to thousands) of numbers in the range I needed. I captured these a comma delimited file that I opened in Excel and looked at the distribution. It was plenty good enough for what I wanted but would not satisfy the lotteries commission.
    If the system has a human operator, I start with a randomised seed as follows:-
    Button is to ground with a resistor pullup to +5V
    Pseudocode
    Pushbutton var portb.0
    w var word
    lcdout $FE, $01, "Press button to start"
    GetSeed:
    random w
    if pushbutton = 0 then SeedFound
    goto getseed
    SeedFound:
    lcdout $FE, $01, "Seed = ", #W
    W is now a random number between 1 and 65535. 0 is never produced. You need to scale this to the range you are interested in either by division as you are doing or by repeating the random instruction until a value that falls in your range is produced. The system is defeated if the user holds the button down before powering up. Needs a check for that.
    This approach relies on a human operator seeing the LCD instruction then pushing the button to stop the counter. Due to reflex times, etc, it generates a pretty good random number.
    If the system has no human to press the button, I have used a fast loop between turn on and the next positive going zero crossing of the mains. This needs an opto or similar way of finding the zero crossing.
    The only better way that I know of is to use a white noise generator.
    Your second code example I think has a problem. I don't think it will ever produce 0 or 1 since it returns to LOOP if time < 2. The random//11 function returns values 0 to 10 so the test for TIME > 10 is never true.
    HTH
    BrianT
    Omaha, Nebraska USA
    You're right, Brian--I was coding from memory and left out an expression in the fifth line:
                 SEED=32771
    LOOP:        RANDOM SEED
                 TIME=(SEED//11)+1
                 IF TIME<2 OR TIME>10 THEN GOTO LOOP
                 TIME=1000*(TIME-1)
                 HIGH LED
                 PAUSE TIME
                 LOW LED
                 PAUSE 1000
                 GOTO LOOP
    That will generate the values 1 to 10.
    I've had to use a similar trick before with other forms of BASIC, notably a tinyBASIC implementation for the 8051 family, because the "ends" of the range (1 and 10) came up disproportionately often.
    If you were satisfied with the distribution based on your empirical test, then it's certainly good enough for any applications I have in mind.
    Thanks for a really good answer!
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Jan 2006
    Istanbul
    Another way of getting a really truly actually indeed working random value and FOR SURE the number you get is always different each time;
    Have the Timer1 running in the background continuously;
    If you need a 16-bit random value, read TMR1L and TMR1H.
    If you need 8-bit value, just read TMR1L.
    Good ? Bad ?
    Quote Originally Posted by sayzer View Post
    Good ? Bad ?
    See Post #3... It's always worked for me.
    Default TMR0 or TMR1 is NO guarantee of a random seed
    Simply reading TMR0 or TMR1 is NO guarantee of a random seed.
    In some systems where the code runs for days and takes innumerable branches and folds it might be pretty good but in other systems the code trajectory is the same every time the code is run. In that case TMR0 and TMR1 will always yield the same values.
    You MUST introduce something truly indeterminate, such as a noise source or an unpredictable delay such as a human operator where response times will vary every time the operator pushes the button.
    BrianT
    Quote Originally Posted by BrianT View Post
    Agreed 100%...but...if running on an internal oscillator, it could vary with temperature, perhaps far enough to mess with the seed enough. After all, theoretically, it only takes a single bit difference to change the order of things completely...theoretically that is
    And exact temperature, therefore precise oscillator speed, is truly indeterminate, if, as you say, you have an external event trigger that is nonperiodic (aperiodic? anti-periodic? periodic-less?)
  1. Random Numbers
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 18th December 2008, 08:47
  2. 6 random numbers limiting to 49 ?????
    Last Post: - 15th June 2005, 23:27
  3. Random number results
    By bartman in forum mel PIC BASIC
    Last Post: - 9th March 2005, 17:39
  4. Random function - How to limit it ??
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 30th November 2004, 14:05
  5. more random number questions
    Last Post: - 14th November 2004, 17:55
