PBP Glcd
Results 1 to 14 of 14
Thread: PBP Glcd
    Sep 2007
    USA, CA
    ...But i'm not going to tell that all C compilers provide tighter code that Basic compilers... there's a load of Bloat one. Same rules apply in asm.. you can create real bloated ASM code. Still bring this... "the power is behind the keyboard" thought
    All compiler support everything... the software programmer (AKA end user) don't
    Ah hah, but not all compilers are equal. PBP was designed with 100% redundancy, and every single command resets the bank registers and program pages. You find this with very few compilers, and it enourmously bloats the code. PBP is an excellent tool for making working code in short time, but it produces very large code that does not run very fast. Compare the output to almost any other compiler... I would be surprised if you find even one compiler that is less efficient with code space or execution time.
    I don't know, I don't care, I don't do any benchmark test, I don't trust any benchmark test, I just find solution... when needed
    I like competition though... unless I wouldn't be able to do what I do on a daily basis. I wouldn't use any PIC24, DsPIC, PIC32 or other Microcontroller brands/model either
    Quote Originally Posted by tenaja View Post
    Just had a good look at one of my .lst files for a rather large program (80K on an 18F4685), using almost all the on chip ram. Went thru and eyeballed most of the MOVLB instructions along with anything else that modified the SFRs. As far as I can tell, PBP/MPASM do a very good job of keeping track where the BSR was to know if it has to be changed to what it needs to be. And I'm sure it's much, much worse on the 10/12/16 series PICs.
    But yes, left to fend for itself, PBP CAN produce very bloated code. That's when it comes down to the keyboard operator to know that DEFINE NO_CLRWDT 1 can easily save a load of space (as is mentioned in the manual, but not directly in so many words), on most PICs, keeping commonly used variables in one bank can also save space/time by not switching banks all the time (mainly on the 10/12/16 series). Would the average programmer know that? Well, I didn't know it at first either. I figured it out accidentally by reading a datasheet one day after about a year of programming with PBP.
    PBP doesn't come with optimizations built-in...true...
    Among the more complicated projects, I've made it do an MP3 player (hard drive/CF based w/external USB support via FTDI), audio spectrum analyzer (128 channel), OBD2 interface (w/ 2 types of GLCD, no assembly required), 36 channel medium freq software based PWM (for LEDs), and so on. Only the spec'an required an assembly subroutine to function. The rest of them could've been done with bone stock PBP...but they weren't
    Not arguing the point (well, maybe a little ), just pointing out a few things that a programmer might learn over time to make PBP a more robust tool.
    Why haven't I bought one of the other compilers with more options built in? Because I've already got a compiler with those options practically built-in (into my head anyways).
    Besides, I've got enough to think about, let alone trying to remember which compiler I'm using for which individual project!
    If you're so dead set against PBP, why are you here?
    Usually i don't use this kind of method, but since it has been posted on the public area, I thought I should share the following with our community...
    http://www.picbasic.org/forum/showth...3926#post63926
    End of post #18 is pretty interesting...
    Knowing Darrel don't use nor have PDS... this show how bad PBP & community is
    Almost sure some other competitor seek through this forum and use it for their own product... but never give credit to whom concern. Benefits and credit goes to the competitors...
    Oh well, that what competition is all about, no complaint when/if it's better!
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. GLCD handling in PBP
    By spreader in forum mel PIC BASIC Pro
    Last Post: - 18th March 2009, 00:58
  3. GLCD Library for PBP
    By octal in forum mel PIC BASIC Pro
    Last Post: - 7th November 2008, 16:21
  4. Compiler differences between PBP 2.33 & 2.46
    Last Post: - 2nd May 2006, 20:01
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
