ICSP not recognizing..
Results 1 to 12 of 12
    Quote Originally Posted by sirvo View Post
    I've also tried the code you wrote Skimask... the oscil. shows ~50kHz... The load you typed is too large...
    Well then change it!
    Or perhaps you wish for me to change the LOAD value myself and re-post the exact same code with that one change so you can cut and paste it over and try it again?
    I never said my code would be perfect, but your code had a few faults that needed to be corrected.
    How accurate you want it?
    Skimask changed the reload value... hence why you have higher value.
    try...
    @       __CONFIG _HS_OSC & _WDT_OFF & _LVP_OFF & _PWRTE_ON & _BODEN_ON
    define OSC 20
    INT       VAR     PIR1.0  ' OVERFLOW flag
    START   VAR     T1CON.0 ' START TMR1
    LOAD     VAR     word
    '------- Configurações iniciais --------------------
    TRISA  = %00000000 ' PORTA
    TRISB  = %00000000 ' PORTB
    TRISC  = %00000000 ' PORTC
    TRISD  = %00000000 ' PORTD
    TRISE  = %00000000 ' PORTE
    OPTION_REG = %00000000
    ADCON1 = %10001111  ' all digital
    T1CON = %00000000   ' TMR1 1:1 prescaler
    PIE1 = %00000001    ' Henable  TMR1 INT
    START = 0
    INT = 0
    LOAD = 65404 '  INT. 36KHz
    @TIMER1=TMR1L
    TIMER1  var word EXT
    ON INTERRUPT GOTO SINUS
    TIMER1=LOAD
    INTCON = %11000000  ' enable global interrupt
    START = 1
    PORTB.0 = 1
    MAIN:
            GOTO MAIN
    DISABLE
    SINUS:
               @ MOVE?CT 0, T1CON, TMR1ON
               TIMER1=TIMER1+LOAD
               @ MOVE?CT 1, T1CON, TMR1ON
               toggle PORTB.0
               INT = 0
    RESUME
    ENABLE
    you should have something like 18KHz signal.. so yeah, your interrupt is still 36Khz... i just toggle the pin..
    I tend to stay away of ON INTERRUPT when i need accuracy. ASM is the best while DT INST with PBP is still good enough for many purpose.
    That is a bit wierd, because what I posted should've had a freq of about 36khz (73.5khz int rate, 20mhz/4=5Mhz instruction rate / 68 = 73.5khz toggling the pin).
    If anything, the freq should've dropped BELOW 36khz due to not reloading the timer with 'fixed' values and not compensating for the extra cycles in the interrupt loop.
    I get the feeling that the 'scope isn't being read right (i.e. only measuring half of the square wave, not the whole thing)
    And yes, I agree completely about DT_INT's vs. ON_Interrupt.
    completely untested, should work anyway...
            define OSC 20
            include ".\include_routines\DT_INTS-14.bas"
    INT_LIST  macro    ;  IntSource,   Label,  Type, ResetFlag?
            INT_Handler    TMR1_INT,  _SINUS,   ASM,  yes
        INT_CREATE
    endasm
    @TIMER1=TMR1L
            TIMER1      var word EXT
            LOAD        CON     65404 '  INT. 36KHz
            TIMER1=LOAD
            START = 1
    @       INT_ENABLE   TMR1_INT
            PORTB.0 = 1
    MAIN:
            GOTO MAIN
    SINUS:
                    MOVE?CT  0, T1CON, TMR1ON ; Stop Timer1
                    MOVLW    LOW(_LOAD)       ; Reload timer1
                    ADDWF    TMR1L,F          ;   but add current Timer
                    BTFSC    STATUS,C         ;       value
                    INCF     TMR1H,F          ;
                    MOVLW    HIGH(_LOAD)      ;
                    ADDWF    TMR1H,F          ;
                    MOVE?CT  1, T1CON, TMR1ON ; Start Timer1
            toggle PORTB.0
    @       INT_RETURN
  1. ICSP and 16F684
    By onaclov2000 in forum Schematics
    Last Post: - 5th March 2009, 18:31
  2. ICSP from EPIC to Breadboard && 16f88
    By rdxbam in forum General
    Last Post: - 14th December 2008, 21:13
  3. Soic Icsp
    Last Post: - 13th September 2008, 20:51
  4. Replies: 1
    Last Post: - 11th December 2007, 00:57
  5. ICSP Programming from a PDA
    By Ralph in forum Off Topic
    Last Post: - 11th November 2007, 23:22
