ICSP not recognizing..
Results 1 to 12 of 12
    Does it always work the first time?
    Try adding capacitors between VDD and VSS. As close as you can to the PIC on both sides. I had a similar problem once with the PICSTART and an 18F'r. ???
    Jan 2007
    Brazil
    Well, I've tried that too... same thing..
    Sometimes it works on the second try... i do not know..
    Well, got another problem, could you help again???
    I'm trying to make TMR1 interrupt at 36kHz.
    It uses a 20Mhz crystal... The code is below:
    @ DEVICE pic16F877, HS_OSC ; System Clock Options
    @ DEVICE pic16F877, WDT_OFF ; Watchdog Timer
    @ DEVICE pic16F877, PWRT_ON ; Power-On Timer
    @ DEVICE pic16F877, BOD_OFF ; Brown-Out Detect
    @ DEVICE pic16F877, CPD_OFF ; Data Memory Code Protect
    @ DEVICE pic16F877, PROTECT_OFF
    define OSC 20
    INT       VAR     PIR1.0  ' OVERFLOW flag
    START   VAR     T1CON.0 ' START TMR1
    LOAD     VAR     word
    '------- Configurações iniciais --------------------
    TRISA  = %00000000 ' PORTA
    TRISB  = %00000000 ' PORTB
    TRISC  = %00000000 ' PORTC
    TRISD  = %00000000 ' PORTD
    TRISE  = %00000000 ' PORTE
    INTCON = %11000000  ' enable global interrupt
    OPTION_REG = %00000000
    ADCON1 = %10001111  ' all digital
    T1CON = %00000000   ' TMR1 1:1 prescaler
    PIE1 = %00000001    ' Henable  TMR1 INT
    START = 0
    INT = 0
    LOAD = 65404 '  INT. 36KHz
    ON INTERRUPT GOTO SINUS
    TMR1L = LOAD.lowbyte
    TMR1H = LOAD.highbyte
    START = 1
    PORTB.0 = 1
    MAIN:
            GOTO MAIN
    DISABLE
    SINUS:  INT = 0
               PORTB.0 = 1 ' JUST TO MEASURE THE FREQ. ON OSCILLOSCOPE
               PORTB.0 = 0
    RESUME
    ENABLE
    The oscilloscope do not shows 35.9kHz, but 30~33kHz...
    Anything I can do?
    Thanks again!
    Sylvio,
    make sure you also disable the LVP mode. This pin have to be loaded to GND when progaming.
    And then... when you reload a 16Bit timer you want to add the reload value instead of just dumping the values in. Finally you want to stop it, then add the reload value, the restart the timer.
    Depending how accurate you want it, not a bad idea to switch to Darrel's instant INTs (PBP or ASM... where asm is always handy .. )
    Try this and see what happens, should give you a 50% duty cycle ~36khz square wave on your o'scope:
    DEFINE OSC 20
    load con 65468:intcon=$c0:option_reg=0:adcon1=$87:t1con=1:pie1=1:c var byte
    TMR1L=LOAD.lowbyte:TMR1H=LOAD.highbyte
    MAIN:      GOTO MAIN
    DISABLE
    SINUS: if pir1.0=1 then
              pir1.0=0:tmr1l=load.lowbyte:tmr1h=load.highbyte:c=c+1:portb.0=c.0
    RESUME
    ENABLE
    And take note of Mr_E's note about adding values.
    Jan 2007
    Brazil
    Thanks for answering..
    I've trie instant interrupts but it stays the same..
    I've also tried the code you wrote Skimask... the oscil. shows ~50kHz... The load you typed is too large...
    Don't know what is wrong.. The oscilloscope is a Tektronix TDS2014.. it is working ok!
    Anything else I can do?
    Let me tell you something.. I'm using 22p capacitor at the @20Mhz... is that ok?
    Sylvio,
    Quote Originally Posted by sirvo View Post
    Well then change it!
    Or perhaps you wish for me to change the LOAD value myself and re-post the exact same code with that one change so you can cut and paste it over and try it again?
    I never said my code would be perfect, but your code had a few faults that needed to be corrected.
    How accurate you want it?
    Skimask changed the reload value... hence why you have higher value.
    try...
    @       __CONFIG _HS_OSC & _WDT_OFF & _LVP_OFF & _PWRTE_ON & _BODEN_ON
    define OSC 20
    LOAD     VAR     word
    START = 0
    INT = 0
    @TIMER1=TMR1L
    TIMER1  var word EXT
    TIMER1=LOAD
    START = 1
    PORTB.0 = 1
    MAIN:
            GOTO MAIN
    DISABLE
    SINUS:
               @ MOVE?CT 0, T1CON, TMR1ON
               TIMER1=TIMER1+LOAD
               @ MOVE?CT 1, T1CON, TMR1ON
               toggle PORTB.0
               INT = 0
    RESUME
    ENABLE
    you should have something like 18KHz signal.. so yeah, your interrupt is still 36Khz... i just toggle the pin..
    I tend to stay away of ON INTERRUPT when i need accuracy. ASM is the best while DT INST with PBP is still good enough for many purpose.
    That is a bit wierd, because what I posted should've had a freq of about 36khz (73.5khz int rate, 20mhz/4=5Mhz instruction rate / 68 = 73.5khz toggling the pin).
    If anything, the freq should've dropped BELOW 36khz due to not reloading the timer with 'fixed' values and not compensating for the extra cycles in the interrupt loop.
    I get the feeling that the 'scope isn't being read right (i.e. only measuring half of the square wave, not the whole thing)
    And yes, I agree completely about DT_INT's vs. ON_Interrupt.
  1. ICSP and 16F684
    By onaclov2000 in forum Schematics
    Last Post: - 5th March 2009, 18:31
  2. ICSP from EPIC to Breadboard && 16f88
    By rdxbam in forum General
    Last Post: - 14th December 2008, 21:13
  3. Soic Icsp
    Last Post: - 13th September 2008, 20:51
  4. Replies: 1
    Last Post: - 11th December 2007, 00:57
  5. ICSP Programming from a PDA
    By Ralph in forum Off Topic
    Last Post: - 11th November 2007, 23:22
