How accurate you want it?
Skimask changed the reload value... hence why you have higher value.
try...
you should have something like 18KHz signal.. so yeah, your interrupt is still 36Khz... i just toggle the pin..Code:@ __CONFIG _HS_OSC & _WDT_OFF & _LVP_OFF & _PWRTE_ON & _BODEN_ON define OSC 20 INT VAR PIR1.0 ' OVERFLOW flag START VAR T1CON.0 ' START TMR1 LOAD VAR word '------- Configurações iniciais -------------------- TRISA = %00000000 ' PORTA TRISB = %00000000 ' PORTB TRISC = %00000000 ' PORTC TRISD = %00000000 ' PORTD TRISE = %00000000 ' PORTE OPTION_REG = %00000000 ADCON1 = %10001111 ' all digital T1CON = %00000000 ' TMR1 1:1 prescaler PIE1 = %00000001 ' Henable TMR1 INT START = 0 INT = 0 LOAD = 65404 ' INT. 36KHz @TIMER1=TMR1L TIMER1 var word EXT '--------------------------------------------------- ON INTERRUPT GOTO SINUS TIMER1=LOAD INTCON = %11000000 ' enable global interrupt START = 1 PORTB.0 = 1 MAIN: GOTO MAIN DISABLE SINUS: @ MOVE?CT 0, T1CON, TMR1ON TIMER1=TIMER1+LOAD @ MOVE?CT 1, T1CON, TMR1ON toggle PORTB.0 INT = 0 RESUME ENABLE end
I tend to stay away of ON INTERRUPT when i need accuracy. ASM is the best while DT INST with PBP is still good enough for many purpose.
