Is Number Odd?
Results 1 to 30 of 30
Thread: Is Number Odd?
    May 2006
    Del Rio, TX, USA
    Aye lad...but if you'll notice...the direct bit checking is not used to determine the final result! A bit like using a pencil to design a machine to manufacture more pencils.
    This could get fun...
    My approach is also somewhat indirect, in that it does not directly check if the number is odd. Rather, it sequentially checks to see if the test number matches a value which is known to be either even or odd.
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by SteveB View Post
    You're pretty much doing the same as Sayzer (comparing with known to be odd / even numbers) -- but the way in which you have it configured to call itself repeatedly until the operation has completed is considered to be recursion. However, normally recursive methods perform the work on the subject and not references.
    Trent Jackson
    May 2006
    Del Rio, TX, USA
    Another recursive method. However this time it uses the unique feature of Variable Rollover. Also, if nothing is found at the end of checking all possible values for a WORD, the outcome must be Zero.
    TestNumber as word
    TestVal as word
    For TestVal = 65534 to 2 step -2
    	If (TestNumber + TestVal)= 0 Then
    		LCDOUT "Even"
    		EndProgram
    	Else
    		If (TestNumber + TestVal) + 1 = 0 then
    			LCDOUT "Odd"
    			EndProgram
    		Else
    	Endif
    Next TestVal
    	LCDOUT "Zero"
    EndProgram:
    EDIT: This may be premature, I think I left a hole at the value of "65535". Standby
    T.Jackson's Avatar
    T.Jackson Guest
    TestNumber as word
    TestVal as word
    		LCDOUT "Even"
    		EndProgram
    	Else
    			LCDOUT "Odd"
    			EndProgram
    		Else
    	Endif
    Next TestVal
    	LCDOUT "Zero"
    EndProgram:
    I don't consider that to be recursive. To be recursive means to have a procedure (method in Java's case) -- that repeatedly calls itself until the operation is complete.
    Kinda like getting a pie that you need to cut up into (n) pieces. Instead of cutting out each piece you cut the whole thing repeadedly until you have (n) pieces.
    Trent Jackson
    May 2006
    Del Rio, TX, USA
    OK, This is better. It has to do one final check after the FOR..NEXT loop.
    TestNumber as word
    TestVal as word
    		LCDOUT "Even"
    		EndProgram
    	Else
    			LCDOUT "Odd"
    			EndProgram
    		Else
    	Endif
    Next TestVal
    If (TestNumber + TestVal) - 1 = 0 then
           LCDOUT "Odd"
           EndProgram
    Else
           LCDOUT "Zero"
    Endif
    EndProgram:
    T.Jackson's Avatar
    T.Jackson Guest
    Recursive example ...
    public int divideBy(int n)
       num = num / n
       if(num > 0)
          divideBy(n);
    It keeps calling itself until we have arrived at something. In PBP you would of course need to exchange the "public int divideBy(int n)" with a label and swap "divideBy(n)" with a goto.
    Trent Jackson
    Mar 2006
    INDIA
    Hi Trent, I think...
    There'r Out of 10's methods. You want's onlyup to 10th.
    So should Listing now.
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  2. dec number to show on lcd (maths)
    Last Post: - 28th August 2007, 19:18
  3. Working with the random number generator
    By kwelna in forum mel PIC BASIC
    Last Post: - 16th January 2007, 17:50
  4. Random number results
    By bartman in forum mel PIC BASIC
    Last Post: - 9th March 2005, 17:39
  5. more random number questions
    Last Post: - 14th November 2004, 17:55
