Is Number Odd?
Results 1 to 30 of 30
Thread: Is Number Odd?
    	If num.0=1 then
    		oddNum = true
    		oddNum = false
    Jan 2006
    Istanbul
    GrandPa's way!
    OddNum = True
    IF Num // 2 = 0 THEN OddNum = False
    Does Num = 1 work?
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by sayzer View Post
    OddNum = True
    Do me a favour and refresh my memory with what "//" does?
    Trent Jackson
    Dec 2005
    Page 32 of the PBP manual defines it as Remainder (Modulus). I believe Modulus or Modulo is the more generally used terminology. It's also more useful, generally, than the other methods suggested as you can use it to test whether any number is evenly divisible by any other number. See...
    Jan 2006
    Istanbul
    Page 32 of the PBP manual defines it as Remainder (Modulus). I believe Modulus is the more generally used terminology. It's also more useful, generally, as you can use it to test whether any number is evenly divisible by any other number.
    Trent Jackson
    I knew it did something for sure; (well, at least at where I am it does).
    Mar 2006
    INDIA
    in VB
    If ((Text1.Text Mod 2) = 0) Then
            MsgBox "Even"
        Else
            MsgBox "Odd"
        End If
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by precision View Post
    in VB
            MsgBox "Even"
        Else
            MsgBox "Odd"
        End If
    That's pretty uncanny bud, because I just wrote this ...
    Dim num As Integer
    Dim oddNum As Boolean
    num = 5
    If num Mod 2 = 0 Then
       oddNum = False
    Else
       oddNum = True
    End If
    I reckon that there's a recursive way of doing it too!
    Trent Jackson
    Mar 2006
    INDIA
    I think only mod formula is easy way to find oddeven.
    oddeven = number mod 2
    if oddeven = 0 then page is even, otherwise odd
    Talking
    How about the most rediculous, long winded, round-about way to do it?
    T.Jackson's Avatar
    T.Jackson Guest
    So to sum it up so far we've got the following, verified to be working solutions.
    1. AND Bitwise operator (My initial approach)
    2. Direct bit checking (Melanie's approach)
    3. Modulus remainder operator (Precision & Sayzer's approach)
    The goal is 10 solutions -- can we do it?
    Trent Jackson
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  2. dec number to show on lcd (maths)
    Last Post: - 28th August 2007, 19:18
  3. Working with the random number generator
    By kwelna in forum mel PIC BASIC
    Last Post: - 16th January 2007, 17:50
  4. Random number results
    By bartman in forum mel PIC BASIC
    Last Post: - 9th March 2005, 17:39
  5. more random number questions
    Last Post: - 14th November 2004, 17:55
