Is Number Odd?
Results 1 to 30 of 30
Thread: Is Number Odd?
    T.Jackson's Avatar
    T.Jackson Guest
    Post Is Number Odd?
    Is there more than one way to test to see if an integer is even or odd? So far I've only been abe to devise one solution. The solution makes use of the AND bitwise operator.
    public boolean isNumOdd(int num)
       if (1 & num)
          return true;
          return false;
    PBP code ...
       if 1 & num then
          oddNum = true
          oddNum = false
       end if
    Has anyone got another way of doing this? I'm incredibly keen to hear your thoughts.
    Best Regards,
    Trent Jackson
    	If num.0=1 then
    		oddNum = true
    		oddNum = false
    Jan 2006
    Istanbul
    GrandPa's way!
    OddNum = True
    IF Num // 2 = 0 THEN OddNum = False
    Does Num = 1 work?
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by sayzer View Post
    OddNum = True
    Do me a favour and refresh my memory with what "//" does?
    Trent Jackson
    Dec 2005
    Page 32 of the PBP manual defines it as Remainder (Modulus). I believe Modulus or Modulo is the more generally used terminology. It's also more useful, generally, than the other methods suggested as you can use it to test whether any number is evenly divisible by any other number. See...
    Jan 2006
    Istanbul
    Page 32 of the PBP manual defines it as Remainder (Modulus). I believe Modulus is the more generally used terminology. It's also more useful, generally, as you can use it to test whether any number is evenly divisible by any other number.
    Trent Jackson
    I knew it did something for sure; (well, at least at where I am it does).
    Mar 2006
    INDIA
    in VB
    If ((Text1.Text Mod 2) = 0) Then
            MsgBox "Even"
        Else
            MsgBox "Odd"
        End If
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  2. dec number to show on lcd (maths)
    Last Post: - 28th August 2007, 20:18
  3. Working with the random number generator
    By kwelna in forum mel PIC BASIC
    Last Post: - 16th January 2007, 18:50
  4. Random number results
    By bartman in forum mel PIC BASIC
    Last Post: - 9th March 2005, 18:39
  5. more random number questions
    Last Post: - 14th November 2004, 18:55
