MPASM Path & File Name Length Limtation
Results 1 to 8 of 8
    Default MPASM Path & File Name Length Limtation
    My PBP file names have always been rather long, containing descriptive text which lets me keep track of program development.
    Today I re-visited a project and found that MPASM, which had previously assembled my files without complaint, now takes exception to combined path & file names which exceed 62 characters.
    Any ideas as to why C:\Program Files\Mecanique\MCS\ZP3084A Cask Kicker Main 18F452 with new auto raise _lower.pbp (93 characters) should have suddenly become unacceptable?
    MPASM reports version 5.16 and MCSP version 3.0.0.5 shows PBP version 2.50A.
    Any help greatly appreciated.
    Brian Walsh.
    Other than the fact that long file names are a bad idea, and really long names are a really bad idea, ....
    http://cquirke.mvps.org/9x/lfns.htm
    Why not use something like:
    Directory Name --- Keep this short too.
    And then the project names.
    proj01
    Projo2
    And keep notes on the projects. The shorter the names the faster the system. Normally.
    Why? I don't know for sure, but your whole path need to be bellow 64 (or something like that) character.
    I sit all my stuff near the root.
    EX: c:\Project\LCDDriver
    C:\Customer\BrianJWalsh\Logger
    As far as i know there's no workaround to this...
    Default MPASM Path Length
    Thanks for your input guys.
    I am prepared to play by the rules and if 64 characters is it, then so be it.
    I'm not short of strategies to stay within the limit ... that wasn't the question. I was simply bewildered by the sudden appearance of a message box telling me that what I had been doing for a year or two was not allowed, together with the implication that it never had been. I am sorry that no light could be shed on that.
    I understand that long file names bring compatibilty problems with legacy software that can't directly support them. We are all familiar with the tilde ~. I don't agree that they are a bad idea. I come from the days of Commodore BASIC (PET) when variable names were limited to two characters ... now that WAS as bad idea!
    Being well behaved I installed MCS+ in the default folder which results in a big long path to my .pbp files. I'm a bit miffed that doing the right thing now limits me to something akin to the straight jacket of the 8.3 file naming convention.
    Thanks again for your interest.
    Brian Walsh.
    Hi Brian,
    Have you tried writing a path statement to direct Windows where to find your files? Here's a link for how to in NT, xp, 2000, and Vista. http://www.computerhope.com/issues/ch000549.htm <br> As to why it changed . . . maybe Windows Update ?
    64 characters may be the limit but any folder can be used as a root folder giving 64 character program names (including folder name) by use of the old DOS command SUBST.
    This works on XP (don't know about Vista) and simply makes a virtual drive out of your code folder.
    Appears as Drive Z: on My Computer as well as in its original location.
    I have used this for years in Proton and the only problem incurred is Norton diskdocter requires an uncheck to this virtual drive.
    Norm
    Vic Wintips&Tricks
    March 17, 2004 - Issue 2
    Archive tip (Updated)
    Original post - Sun Nov 12, 2000
    Create Virtual Drives Using the Subst Command
    (applies to all versions of Windows)
    Here's a Windows trick that's not that well known unless you know Dos.
    Did you know you can create a virtual drive to any folder on your system?  For
    example,
    you can turn your Windows directory
    into a W drive that will appear inside My Computer looking just like any other
    drive and
    accessible just like any other drive.
    You do this using the SUBST command which stands for substitute. It's easy.
    Here's how you would create the example W: drive for the Windows folder:
    Click Start>Run, enter this command:
    SUBST W: C:\WINDOWS
    and click OK
    Done!
    You now have a virtual W drive in My Computer that opens up Windows when
    doubled clicked
    (go take a look)
    You can access a virtual drive just like you would any other drive. For
    example, you can
    simply enter W: in the Run box, at a
    Dos prompt, in a bat file, or even shortcut to open up the Windows directory.
    Another example:
    Make a drive out of your Temporary Internet Files folder.
    Just change the path in the example below to match your user name and the path
    to your own
    SUBST T: "C:\Documents and Settings\YOUR USER NAME\Local Settings\Temporary
    InternetFiles"
    (the quotation marks are essential)
    This would give you a T: drive and allow you to access your  Temporary Internet
    Files by
    simply entering T: in the Run box or at a
    command prompt(or in  a shortcut even)
    Not overy useful, I know, but could be handy if you ever need to access your
    TIF folder in
    Dos since you don't have to type the
    entire path or do any directory switching to get to it.
    But if you do want to put this tip to use and keep the virtual drive intact,
    then there's
    something else you need to do.
    By default, the virtual drive will only last until you reboot. To keep it, you
    need to
    have the command load at startup.
    In Windows 9x, you can do this by placing the command in your autoexec file or
    for all
    Windows versions,  in any bat file which you
    can  then place in your Startup folder which you can access by right clicking
    the Start
    button, choosing Open. You will find your
    Startup folder in the Programs folder.
    Here is how to create a simple bat file inside your Startup folder:
    We'll use the letter W: assigned to C:\Windows, in this example.
    Right click an empty area inside your Startup folder and click New>Text
    Document.
    Open up the newly created notepad document and enter these commands
    @echo off
    subst W: C:\Windows
    cls
    Save the txt file and then rename it with a .BAT extension.(click yes when
    asked to
    confirm the name change)
    Done.  Now, the bat file will load each time you startup to make sure the
    Virtual drive
    remains.
    Deleting a Virtual Drive
    To delete a virtual drive, use the /d switch.
    Example - to delete virtual drive W, you would enter:
    SUBST W: /d
    in the Run box or at a command prompt.
    but as stated, in Windows the drive only lasts until you reboot anyway so just
    removing
    the startup command to it should get rid of it as well.
    vic
    May 2008
    Florida
    I use Thumb drives, that way I can have as many as I need and my C drive doesn't get as fragmented. An added bonus is I can work on any computer I am using.
    Another advantage of a thumb drive is it can be removed
    from the PC when not in use for safety from lighting strikes.
    I use one for code backup.
    Norm
  1. 2550 in a coma, mpasm 4k of errors, inc file notfound
    By f_lez in forum mel PIC BASIC Pro
    Last Post: - 26th June 2007, 18:42
  2. The ultimate include file
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 26th January 2007, 20:35
  3. 18F8722 and MPASM confusion!
    By Jackson in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2006, 02:24
  4. Converting to MPASM
    Last Post: - 4th November 2005, 02:35
  5. New Mecanique USB HID maker
    By mister_e in forum General
    Last Post: - 16th July 2005, 00:23
