PicBasicPro Code help!
Results 1 to 4 of 4
    May 2008
    Smile PicBasicPro Code help!
    Hi!
    I'm new to PIC programming....I have done projects with Basic Stamp 2...
    Two codes question;
    With a ex VAR WORD (ex=2343). How do I get the digit 2 with picbasic pro?
    With basicstamp it's NIB 3. (starting from the right from 0).
    Other question;
    I have a 40 pin PIC (16f877) and wanna get PORTB (rb0,rb1,rb2 and rb3) to output and ascii number all together.How do I do it with picbasic pro?
    With basic stamp here is te code, LOW and HIGH port can be used.
    LEDs VAR OUTD ' LEDs on P12 - P15
    LEDsDirs VAR DIRD ' DIRS control for LEDs
    display VAR OUTC ' Transistors on P8 - P11
    cntdisplay VAR DIRC ' DIRS control for Transistors
    LEDs = 2 (pin 12 t0 15 will output 2)
    Tank you....(don't forget beginner) ...
    Salut Michel,
    NIB 3 should be DIG 3 in PBP, refer to section 4.17.7 of your manual
    TRISB=0 ' all PORTB i/o = output
    PORTB=YourVariable ' use with care
    Refer to section 10 for PIcBasic VS Stamp difference.
    May 2008
    Default Hi mister_e!
    Tanks for the first question....
    But the second....portB has 8 pins rb0 to rb7 and I have to define the 4 pins (0 to 3) only to use for output my number. I have, imagine to dfive one variable with those 4 pins and than ....
    Can i say ex = portB.low...let's say! and than ex = 2
    Thanks again!
    May 2008
    Default Finaly got it!
    Made my protoboard and finaly found the code for assinging port pins.
    TRISB = %00000000
    x var byte
    Leds var byte
    Digs var byte
    ENABLE DEBUG
    for x = 0 to 9
    leds = x
    Digs = x
    GOSUB PORTSsegments
    gosub PORTSdiggits
    Pause 500 ' Delay for .5 seconds
    leds = %0000
    Digs = %0000
    GOSUB PORTSsegments
    gosub PORTSdiggits
    next x
    Goto main ' Go back to loop and blink LED forever
    PORTSsegments:
    PortB.0 = leds.0 : PortB.1 = leds.1 : PortB.2 = leds.2 : PortB.3 = leds.3
    PORTSdiggits:
    PortB.4 = Digs.0 : PortB.5 = Digs.1 : PortB.6 = Digs.2 : PortB.7 = Digs.3
    DISABLE DEBUG
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 02:43
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
