DS1820 - Help I'm rusty !
Results 1 to 21 of 21
Threaded View
  1. #13
    Hi, Malc
    If your sensor gives ONE TIME the correct temp ...
    it is obvious ... you forgot to close the never-ending measuring Loop ... ( Mr de la Pallice )
    Did you modify the program ??? ( else than just config bits, Osc speed ... etc )
    -23tC 0.06 -28T
    This should tell your DS 1820 is in a freezer ...
    is it the truth ???
    I will do a test ( must solder a dedicated cable ) to see if I can have a delicious ice-cream ...
    the first line indicates : Bottom value of scale, actual temp, Top value of scale
    second line is scale and index showing where you are between Bottm value and Top value ...
    The "rocket" means the heating Output is ON ...
    I give you the test results for negative temp ... keep on the line !
  1. Please help with 1-wire DS1820
    By hatuan291 in forum mel PIC BASIC Pro
    Last Post: - 9th March 2010, 14:51
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
  3. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 14:12
  4. PIC lcd ds1820
    By wchpikus in forum mel PIC BASIC
    Last Post: - 24th May 2007, 15:46
  5. DS1820 again
    By paxmowa in forum mel PIC BASIC Pro
    Last Post: - 10th January 2006, 15:49
