OK, just received some extra goodies for my easyPIC5 board, one of which is a DS1820 temp sensor. I've used Bruce's example as a starting point and edited it to work with the 2 x 16 LCD on the EasyPIC5 board, but I don't get anything displayed on the screen.
Its been a while since I did any programming, so I'm a tad rusty, Can someone give me some direction. Here are the main points:
16F887 running with 20Mhz
DS1820 output set to RA5
LCD on portB as per the user manual
TRISA=%11111111                                                 ' set PORTA as all input
TRISB=%00000000                                                 ' set PORTB as all output
DEFINE OSC 20
DEFINE LCD_DREG PORTB                                           ' LCD data port
DEFINE LCD_DBIT 0                                               ' LCD data starting bit 0 or 4
DEFINE LCD_RSREG PORTB                                          ' LCD register select port
DEFINE LCD_RSBIT 4                                              ' LCD register select bit
DEFINE LCD_EREG PORTB                                           ' LCD enable port
DEFINE LCD_EBIT 5                                               ' LCD enable bit
DEFINE LCD_BITS 4                                               ' LCD bus size 4 or 8
DEFINE LCD_LINES 2                                              ' Number lines on LCD
DEFINE LCD_COMMANDUS 2000                                       ' Command delay time in us
DEFINE LCD_DATAUS 50                                            ' Data delay time in us
Comm_Pin    VAR	PortA.5                                         ' One-wire Data-Pin "DQ" on PortC.0
Busy        VAR BIT                                             ' Busy Status-Bit
TempC       VAR WORD                                            ' Temp in deg C
TempF       VAR WORD                                            ' Temp in deg F
Float       VAR WORD                                            ' Holds remainder for + temp C display
Cold_Bit    VAR  R_Temp.Bit11                                   ' Sign-Bit for +/- Temp. 1 = Below 0 deg C
Real_Cold   CON 1                                               ' Define Real_Cold = 1
Deg         CON 223                                             ' Data to display Deg ° symbol
Sign        VAR BYTE                                            ' +/- sign for temp display
Dummy       VAR BYTE                                            ' Dummy for Div32
Start_Convert:
    OWOUT   Comm_Pin, 1, [$CC, $44]                             ' Skip ROM search & do temp conversion
Wait_Up:
    OWIN    Comm_Pin, 4, [Busy]                                 ' Read busy-bit
    IF      Busy = 0 THEN Wait_Up                               ' Still busy..?, Wait_Up..!
    OWOUT   Comm_Pin, 1, [$CC, $BE]                             ' Skip ROM search & read scratchpad memory
    OWIN    Comm_Pin, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]      ' Read two bytes / end comms
    GOSUB   Convert_Temp
    GOTO    Start_Convert
Convert_Temp:                                                   ' +32.0 to +257 F
    IF      Cold_Bit = Real_Cold THEN Yikes                     ' If Cold_Bit = 1, it's below "0" deg C
    Sign  = "+"
    Dummy = 625 * R_Temp                                        ' Multiply to load internal registers with 32-bit value
    TempC = DIV32 10                                            ' Use Div32 value to calculate precise deg C
    Dummy = 1125 * R_Temp
    TempF = DIV32 100
    IF TempF >6795 THEN                                         ' Over 99.5 deg F..?
       TempF = TempF + 3200
       lcdout $FE, 1," TempF = ",Sign,DEC TempF DIG 4,_
       DEC TempF DIG 3,DEC TempF DIG 2,".",DEC2 TempF,Deg,"F "
       LCDOUT $FE,$C0, " TempF = ",Sign,DEC TempF DIG 3,_
    TempC  = (R_Temp & $0FF0) >> 4                              ' Mask middle 8-bits, shift into lower byte
    Float = ((R_Temp.Lowbyte & $0F) * 625)                      ' Lower 4-bits of result * 625
Yikes:                                                          ' Display full range -C to -F conversion
    Sign   = "-"                                                ' Display - symbol for negative temp
    Dummy  = 625 * ~R_Temp+1                                    ' Multiply to load internal registers with 32-bit value
    TempF  = ~R_Temp / 16                                       ' Begin conversion from -C to deg +/-F
    IF TempF >=18 THEN                                          ' Check for -degrees F "-18 C = -0.4 F"
       TempF   = ((((TempF + 50) * 9) /5) -122)                 ' -C to -F below -17 deg C
       lcdout $FE, 1," TempF = ",Sign, DEC TempF,Deg,"F     "
       LCDOUT $FE,$C0, " TempC = ",Sign,DEC TempC DIG 4,_
       DEC TempC DIG 3,".",DEC3 TempC,Deg,"C "
    ELSE                                                        ' Else result = +deg F
       TempF   = ((((-TempF + 50) * 9) /5) -58)                 ' -C to +F below 32.0 deg F to -17 deg C
     lcdout $FE, 1, " TempF = ","+",DEC TempF,Deg,"F     "
      LCDOUT $FE,$C0 , " TempC = ",Sign,DEC TempC DIG 4,_
There are a few compiling errors,
Cold_Bit VAR R_Temp.Bit11 gives "a bad data type"
OWIN Comm_Pin, 2, [R_Temp.Lowbyte, R_Temp.Highbyte] gives "expected [" and "expected ]" even though the exist
and half a dozen "bad expressions"
The example was for a serial LCD, where as mine is a traditional parallel one in 4 bit mode, so I've tried to convert the example, but its not displaying anything, even though it was cut and pasted from a bit of code I wrote a year ago which worked (just changed portC to port B for the use on the development board)
I'm sure its missing something really obvious. Should I still configure the chip, or use the settings in the Flash2 programmer software.
TIA
