Alternative Methods ...
Results 1 to 4 of 4
    T.Jackson's Avatar
    T.Jackson Guest
    Default Alternative Methods ...
    Algorithm to see how many variables are the same ...
    I finished my final unit for Java last week. In the examination there was a question that asked for a method to be written to check to see how many elements in an array contained the same values. Given that there were only 3 elements in the array, the most obvious solution would be to resort to the humble 3-bit truth table and implement an IF statement containing ANDs / ORs. But I wanted to do things differently, I thought outside the square, this is what I came up with ...
    public int getObjectsAtSameDistance()
       int ObjectsSameDistance;
       // Scan thru array and see how many objs are at the same distance
       for (int j = 0, j < 2, j++)
          for (int i = j + 1, i < 2, i++)
             if (distances[j] == distances[i])
                objectsSameDistance ++;
                break;
       if (objectsSameDistance > 0)
       return objectsSameDistance;
    The more traditional approach for something like that would be this ...
       if (distances[0] == distances[1] && distances[2] == distances[0])
          objectsSameDistance = 3;
       elseif (distances[0] == distances[1] || distances[1] == distances[2] || distances[0] == distances[2])
          objectsSameDistance = 2;
    Doing things like can quickly become unmanagable when there's lots of elements in the array.
    The truth table below supports the solution, whereas a = the first element in the array and c is the last ...
    abc
    000
    001
    010
    011
    100
    101
    110
    111
    I'm fully aware that this is a PBP forum and not Java, so I have ported the code to PBP below for those who wish to give it a whirl ..
       objectsSameDistance var byte
       for j = 0 to 2
          for i = j + 1 to 2
             if distances[j] = distances[i] then
                objectsSameDistance = objectsSameDistance + 1
                exit for
             end if
          next
       next
    Best Regards,
    Trent Jackson
    This looks like the old bubble sort algo. I guess that with many elements it will take cosiderable time, won't it?
    T.Jackson's Avatar
    T.Jackson Guest
    Add in a few additional operations and it would become a bubble sort algo ...
    1. Sample compare swap
    2. Adjust pointer position
    I wrote a complete bubble sort program late last year ...
    '~ Bubble sort by Trent Jackson                     08/08/07                                                '
    import java.util.Scanner;
    import java.util.Random;
    public class NumberSort
       private static final String TERMINATE_PROG = "x";
       private static int [] rndArray = new int[10000];
       private static Random generator = new Random();
       public static void main(String[] args)
          Scanner keyboard = new Scanner(System.in);
          boolean runprogram = true;
          int intkey = 0;
          String strKey;
          genNums();
          do
             System.out.println();
             System.out.println("******** Number Sorting Algorithm Menu ********");
             System.out.println("A. Generate 10,000 new random numbers ...");
             System.out.println("B. Sort numbers & display time taken in mS");
             System.out.println("C. Print array of numbers");
             System.out.println("X. Exit the program");
             System.out.println("***********************************************");
             System.out.print("Select one of the options above: ");
             strKey = keyboard.next(); // Wait for menu selection
             if (strKey.equalsIgnoreCase(TERMINATE_PROG))
                runprogram = false;
             else if (strKey.equalsIgnoreCase("a"))
                genNums();
             else if (strKey.equalsIgnoreCase("b"))
                sortNums();
             else if (strKey.equalsIgnoreCase("c"))
                printNums();
          } while (runprogram == true); // Go back and do it all again until user quits ...
       public static void genNums()
          // Generate 10K worth of random numbers between (0 - 32,000)
          for (int i = 0; i < 10000; i++)
             int rnd = generator.nextInt(32000);
             rndArray[i] = rnd;
       public static void sortNums()
       // Basically, this algo will sort an array of numbers from lowest to highest.
       // Starting from the top of the list we attempt to find a larger number than
       // the one at the bottom. When we do, we swap them.
          int compareA = 0;
          int compareB = 0;
          int swap = 0;
          int arrayPos = 0;
          int i = 9999;
          int j = 0;
          // Sample system time
          long startTime = System.currentTimeMillis ();
          do
             compareA = rndArray[i];
             for (j = arrayPos; j < i; j++)
                compareB = rndArray[j];
                if (compareB > compareA)
                   swap = rndArray[i];
                   rndArray[i] = compareB;
                   rndArray[j] = swap;
                   arrayPos = j;
                   break;
             if (j == i)
                i --;
                arrayPos = 0;
          } while (i > 0);
          // Sample system time  & calc time elapsed
          long finishTime = System.currentTimeMillis ();
          System.out.println("Time taken to sort 10,000 unordered numbers: " + (finishTime - startTime) + "mS");
       public static void printNums()
          for (int i = 0; i < 9999; i++)
             System.out.println(rndArray[i]);
    Trent Jackson
    T.Jackson's Avatar
    T.Jackson Guest
                break;
    There is actually a problem with this method the more I think about it. Works fine for 3 elements / variables, but what if there's say 5, whereas 3 of them = 100 and the other 2 = 50 -- which ones do we report as being the same? As is the code will return a value of 5.
    The solution is limited but not flawed ...
    Trent Jackson
  1. Alternative for 'printf'
    By Sach_1979 in forum General
    Last Post: - 25th September 2009, 01:02
  2. Pulsin alternative
    By sbobowski in forum mel PIC BASIC Pro
    Last Post: - 4th October 2008, 09:21
  3. Alternative to the H44780 lcd controler
    By Sphere in forum Off Topic
    Last Post: - 31st July 2008, 19:17
  4. alternative Pin for vref
    By ruijc in forum General
    Last Post: - 15th January 2008, 10:46
  5. Alternative power supply
    Last Post: - 20th November 2007, 13:38
