Hi all
Is it possible to write a program using a pin in both analog and digital one at a time.
Meaning: I would like to implement two loop, one loop uses a porta.0 analog mode and another loop using the same pin in digital mode.
I would switch between the two using and switch, so I only one of the two.
Example:
if PortB.0 = high then
ADCON1 = %10000010
'use PortA.0 in analog mode
if PortB.0 = Low then
ADCON1 = %10000000
'use PortA.0 in digital mode
K
