syntax error
Results 1 to 3 of 3
Thread: syntax error
    Jun 2008
    Chicago suburb
    Question syntax error
    Could somebody point out to me what is wrong with my code?
    I don't know where I went wrong.
    __________________________________________________ __________________________
    TRISB = %11111111 'PORT B ALL INPUTS
    TRISA = %00000000 'PORT A ALL OUTPUTS
    WAIT IF PORTB.3 = 1 THEN TIMEON 'WAIT UNTIL INPUT PULSE ARRIVES
    GOTO WAIT 'LOOP BACK TO WAIT
    TIMEON HIGH PORTA.1 'PULSE ARRIVED AT PIN 4 SET PIN 9
    'HIGH
    PAUSE 10 'PAUSE FOR 10 msec
    LOW PORTA.1 'SET PORT A BACK TO LOW
    GOTO WAIT 'RETURN BACK TO WAIT
    All this programm does it takes a pulse in on port b pin 3 and sets an output
    port a pin 1 high for an extended time of 10mS (the input is only 50uS wide)
    The syntax error starts at the lable 'WAIT' and goes all the way down to the end.
    I have not worked with PBP for a while and in the past I used the DOS version and
    I had no problems with it.
    WAIT is a reserved word. It belong to some Serial communication command such as SERIN2, DEBUGIN and HSERIN.
    There's a list of reserved word in your manual.
    Usually, wen you define LAbel, you should add a colon after it.
    WaitingForSomething:
            GOTO WaitingForSomething    'LOOP BACK TO WAIT
    TIMEON:
            GOTO WaitingForSomething    'RETURN BACK TO WAIT
    HTH
    Jun 2008
    Chicago suburb
    Smile mister e
    Thank you very much. I knew it had to be something like that.
    It is compiling ok now.
    Thank you again
    Gerd
  1. Compile error & syntax error on the word "loop:" as a label?
    Last Post: - 7th March 2010, 05:14
  2. Loop with two motor and 2 sensors
    Last Post: - 9th December 2008, 00:40
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
  5. Syntax error PIC16F684
    By milestag in forum mel PIC BASIC Pro
    Last Post: - 21st September 2005, 19:54
