PIC14000 adc
Results 1 to 2 of 2
Thread: PIC14000 adc
    Doug's Avatar
    Doug Guest
    Default PIC14000 adc
    Does anyone have any code for reading the adc in a pic14000. PBP's adcin does not support pic14000.
    Thanks in advance.
    I never use PIC1400 but the following work on 16F877 without using ADCIN, maybe you can use a part of it. Compare both datasheet may help if there's any difference between both
    A_D_Val  VAR BYTE
    TRISA = %11111111  ; Set PORTA to all input
    ADCON1 = %00000010 ; Set PORTA analog and LEFT justify result
    ADCON0 = %11000001 ; Configure and turn on A/D Module
    Pause 500
    Start:
    ADCON0.2 = 1 ;Start Conversion
    ConversionNotcomplete:
         pause 10
         if ADCON0.2 = 1 Then ConversionNotComplete
         adval = ADRESH
         Lcdout $fe, 1,"Result=",DEC A_D_Val
         Pause 200
         Goto Start
    hope this may help!!!
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 16:33
  3. PIC18F2423, ADC problem
    By mistergh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 02:31
  4. ADC value with 2 decimals on an LCD
    By Squibcakes in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2005, 16:54
  5. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 02:55
