negative pulse I/O pin how to?
Results 1 to 12 of 12
    A cap on the output, charge it up, then dump the charge. You'll get a negative spike, but that's about it.
    If you read the datasheet for your particular PIC, you'll see under the 'Absolute Maximum Ratings' that negative voltages ( Vss - .3v depending on your PIC ) can damage your device.
    Simple way - Charge pump - ICL7660/ICL7662 - using a pin on the PIC and a transistor or MOSFET to control that output.
    May 2008
    Hi Skimask
    Your way ahead of me.
    So I can use a cap. and charge it with a + voltage
    and use the -neg. to trigger the led?
    I think thats what your saying.
    Im a newbe and dont understand the transistors I
    know thay up the +volts from a pic chip pin.
    I see now I need to look in to changing + V to -V.
    I dont know how to do this.
    O boy did I take a big byte this time.
    HELP!
    May 2008
    Thumbs up
    I just did some reading and I see that transistors work on the
    -neg. side I thank.
    This is good to know. See I dont know to much yet.
    Thanks for the input it helps.
    Ill have some more dumb Qs soon.
    Im a hobby electronic guy I just found the pic chip and what
    you can do with it a short time ago. It is so cool what you can do.
    And its not that much cash to get going.
    I did hand over the $250.00 for the full picbasic pro ver.
    That was a pane in the paycheck but I like it.
    So Im hooked on this stuff for now.
    Thank you guys!
    Do you have a dual power supply set up for this project? Do not know what you are up to, but might make things easier for you to get the negative you want.
    Don't really understand why you need a negative trigger in the first place....mainly because you haven't given us any information on the 'chip' that you're using. Might just be reading the datasheet wrong.
    Unless you're confusing 'negative' with 'ground', sort of the way a lot of people think a 12v car battery has a +12v and a -12v, when in reality, it's +12v and common (or if you want the other way, common and -12v). LEDs, or circuits for that matter, don't GENERALLY require a positive and negative voltage, they need a voltage differential. Doesn't matter if you've got +5v/common (0v) or 105v/100v, both of them have a 5v differential.
    Exclamation
    Hi, Ricky
    I already see some smoke from my location ...
    you'd better tell us what reference is your LED ( or where it comes from: link , please ! ).
    negative triggering means triggering with a +5v - 0 v - 5v pulse ...
    ... my two cents.
    May 2008
    Thumbs up
    Ok I got the led from radio shack.
    Its brand new 7 colors.
    The led has 3 leads coming from it.
    One is the cathode or negative.
    One is the anode or positive.
    There is a third pin and this pin is the trigger
    for the microchip in the LED.
    The trigger is tripped with a ground or negative charge.
    This LED is so new mouser and digi key dont have it.
    There is no data sheet and you have to get it for your self.
    So there is no way to set a pin to ground and then set it to nutral?
    Not + and not - neg.
    I use a 16f84a for most projects but I have some 18f2620 that I like.
    Some help with pin info would help or where to get it from.
    Like the pins have a lot of different uses RC6/TX/CK
    Pin address/?/?
    What do these mean?
    Or where can I get the info
    on what these mean?
    Just here for fun and I dont want to make waves.
    Just trying to keep my old mind sharp.
    Thanks for any input you may have.
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. Microcontroller with 2 way paging application problem
  3. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
  4. Grounding Negative voltage through I/O pin
    By Squibcakes in forum Schematics
    Last Post: - 31st July 2006, 12:12
  5. I/O pin and MCLR
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 15th July 2004, 10:52
