Hello all. I have created a program that runs perfectly fine on a PIC16F690. The only problem is that I have run out of memory space on the 16F690 so I decided to move to a chip that has a larger memory. I am trying to use the PIC18F4525 but I cannot get the LCD to function properly. Upon power-up, I have a pin flash an LED so I know the micro is working but the display is just showing a divison sign. I am using a PICSTART Plus to program the 18F4525 and am using PICBASIC PRO 2.50A. I have the LCD attached to PORTD of the micro and I am using an external crystal that is 4 Mhz. I have tried two different LCDs but get the same results with each one.
Is there anything that discusses using PICBASIC Pro with the 18F series? I have looked through the datasheet and tried looking all through the forum. The only thing I can find is that a lot of people have problems with the configurations fuses with the 18F series. I was having problems as well but I have just commented out them out for the time being. I set the config bits in MPLAB prior to programming the 18F4525. I don't really know much about modifying the .inc files. If there are any guides on this, this would be quite helpful as well.
If anyone can please provide me with any ideas I would greatly appreciate it.
Here is a some of the code.
include "modedefs.bas"
DEFINE SER2_BITS 9
DEFINE ADC_BITS 10    ' set number of bits in result
DEFINE ADC_CLOCK 5    ' set clock source
DEFINE ADC_SAMPLEUS 50   ' set sampling time for microseconds
DEFINE LCD_DREG    PORTD  'set LCD DATA port
DEFINE LCD_DBIT    4       'set starting DATA bit (0 or 4) if 4-bit
DEFINE LCD_RSREG    PORTD   ' Set LCD Register Select port
DEFINE LCD_RSBIT	2       ' Set LCD Register Select bit
DEFINE LCD_EREG	PORTD       ' Set LCD Enable port
DEFINE LCD_EBIT	3           ' Set LCD Enable bit
DEFINE LCD_BITS	4           ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES	2       ' Set number of lines on LCD
DEFINE LCD_COMMANDUS    2000  ' Set command delay time in us
DEFINE LCD_DATAUS	50      ' Set data delay time in us
'CONFIG1H = %11000001      ' Oscillator switchover enabled
                          ' Fail safe clock monitor enabled
                          ' XT oscillator
'CONFIG2L = %00011000      ' Brown out reset voltage setting minimum setting
                          ' Brown-out reset disabled
                          ' Power up timer enabled
'CONFIG2H = %00000000      ' WDT disabled
'CONFIG3H = %00000000      ' MCLR disabled
                          ' Timer 1 configured for High power op
                          ' PORTB4:0 are digital IO
                          ' CCP2 muxed with RB3
'CONFIG4L = %11000000      ' background debugger disabled
                          ' instruction set enstions enabled
                          ' Single suppoly ICSP enabled
                          ' stack full/underflow will not cause a Reset
'CONFIG5L = %00000000      ' code protection bit for all blocks
'CONFIG5H = %11000000      ' Data EEPROM not protected
                          ' Boot block not protected
'CONFIG6L = %00001111      ' no write protection bit for all blocks
'CONFIG6H = %11000000      ' no write protection bit for Data EEPROM
                          ' and Boot Block
                          ' Configuration is write protected
'CONFIG7L = %0000000       ' no protection for table reads
'CONFIG7H = %0100000       ' no protection for table reads for boot block
CMCON = 7
ADCON1 = %00001111        ' Voltage reference Vss
                          ' Voltage reference Vdd
                          ' all pins digital
'ADCON2 = ???             ' this needs to be set up if A to D used
'ANSEL = %00000000        ; all digital
'ANSELH = %00001000       ; AN11 is analog
OSCCON = %01101100       ' internal Osc of 4 MHz
WDTCON = %00000000       ' Watchdog timer is off
TRISA = %11011110        ; define Inputs and Outputs
TRISB = %10101111
TRISC = %00000000
TRISD = %00010000
TRISE = %00000000
PORTA = %00000000
PORTB = %00000000
PORTC = %00000000
PORTD = %00000000
PORTE = %00000000
LATA  = %00000000       ' Data latch register
LATB  = %00000000       ' Data latch register
LATC  = %00000000
LATD  = %00000000
LATE  = %00000000
INTCON = %00000000
INTCON2 = %10000000     ' PortB pullups disabled
PIE1  = %00000000       ' disable peripheral interrupts
PIE2  = %00000000       ' disable peripheral interrupts
'OPTION_REG = %11100000
'WPUA = %00000000
'WPUB = %00000000
CCP1CON = %00001100     ' setup the PWM module for single output on RC5
'PORTA definitions
TEST_OUTPUT         VAR PORTA.0
TRANSMIT_OUT        VAR PORTA.4
RECEIVE_IN          VAR PORTA.5
'PORTB definitions
FUNCTION_BUTTON     VAR PORTB.0
UP_BUTTON           VAR PORTB.1
DOWN_BUTTON         VAR PORTB.2
SET_BUTTON          VAR PORTB.3
'ANALOG_INPUT        VAR PORTB.5
'SERIAL_OUTPUT       VAR PORTB.6
AD_AN11_VALUE        VAR WORD
AD_AN11_VOLT         VAR WORD
UP_VENT_SETTING      VAR BYTE ' WORD   ' ON = VENT
UP_FILL_SETTING      VAR BYTE ' WORD   ' OFF = Fill
DOWN_VENT_SETTING    VAR BYTE ' WORD  ' ON = VENT
DOWN_FILL_SETTING    VAR BYTE ' WORD  ' OFF = Fill
UP_PULSES            VAR BYTE
DOWN_PULSES          VAR BYTE
CHECKSUM_BYTE        VAR BYTE
CHECKSUM_WORD        VAR WORD
REC_CHECKSUM_VALUE   VAR WORD
DUTY                 VAR WORD
UP_VALUE             VAR word
DOWN_VALUE           VAR Word
UP_TRIP_ADJUST       VAR WORD
DOWN_TRIP_ADJUST     VAR WORD
DECAY_VALUE          VAR BYTE ' WORD
TOLERANCE_VALUE_UP   VAR BYTE ' WORD
TOLERANCE_VALUE_DOWN VAR BYTE
A0  VAR BYTE
A1  VAR BYTE
A2  VAR BYTE
A3  VAR BYTE
A4  VAR BYTE
C1  VAR Byte
C0  VAR BYTE
C6  VAR BYTE
C7  VAR BYTE
D0  Var Byte
D1  VAr Byte
D2  VAr Byte
D3  Var Byte
i   VAR BYTE
MODE    VAR BYTE        ' used to determine which function
                        'should be incrementing
                        ' MODE 1 A to D setting
                        ' MODE 2 MIN SETTING
                        ' MODE 3 MAX SETTING
UPDATE  VAR BYTE        'UPDATE bit 0, used for returning from Interrupts
                        'UPDATE bit 1, used to indicate Manual Mode
                        'Update bit 2, 1 = step 1
                        'Update bit 3, 1 = step 2
                        'Update bit 4, 1 = step 3
                        'Update bit 5, 1 = step 4
'---------- program starts here
'              0, 1,  2, 3,  4,  5,  6, 7, 8,  9, 10, 11, 12, 13, 14,15,16,17, 18,19, 20, 21, 22, 23, 24, 25,26,27,28,29,30,31,32
DATA          16, 0, 30, 0, 25, 50, 50, 0, 0, 200, 0,  0,  0,  0, 16, 0, 2, 0, 29, 0, 9, 96,273, 148, 20, 20, 0, 0, 0, 0, 0, 0,00
    TEST_OUTPUT = 1
    PAUSE   500
    TEST_OUTPUT = 0
    PAUSE 500
		T2CON = %00000101		' Turn on Timer2, Prescale=4
' Use formula to determine PR2 value for a 1KHz signal,
' 4MHz clock, and prescale=4. (4E6/(4*4*1E3))-1=249
		PR2 = 249				' Set PR2 to get 1KHz out
' Use formula to determine CCPR1L:CCP1CON<5:4> value for
' ends of range 20% to 80%.  (249+1)*4*0.2=200 (20% value)
' (249+1)*4*0.8=800 (80% value)
        READ  8, DUTY.HIGHBYTE
        READ  9, DUTY.LowBYTE
        Pause 10
        DUTY = DUTY
loop:	CCP1CON.4 = duty.0		' Store duty to registers as
		CCP1CON.5 = duty.1		' a 10-bit word
		CCPR1L = DUTY >> 2
		duty = duty + 10		' Increase duty cycle
    Pause   200       ' Wait for LCD to startup
DISPLAY_MODE_SELECT:
    GOSUB   CLEAR_LCD
    LCDOUT  "Push Function"
    LCDOUT  $FE, $C0, " to setup values"
LOOK_FOR_BUTTON_PUSH:
    BUTTON  FUNCTION_BUTTON, 1, 255, 0, A3, 1, SETUP
    BUTTON  SET_BUTTON, 1, 255, 0, A2, 1, CONTRAST
    'GOSUB   MODE_BUTTON_PUSH
    PAuse   10
    GOTO    LOOK_FOR_BUTTON_PUSH
