DC motor parameters estimation !
Results 1 to 2 of 2
    Question DC motor parameters estimation !
    hi all,
    I need your help, experience, references, or hints on how to estimate the parameters for any DC motor , like these parameters
    These are the motor parameters that are needed:
    Motor voltage constant Ke (volts-sec/rad)
    Motor torque constant KT (lb-in/amp)
    Motor resistance Ra (ohms)
    Motor inductance La (Henries)
    Motor inertia Jm (lb-in-sec^2)
    Load inertia reflected to the motor armature shaft Jload (lb-in-sec^2)
    because sometimes we find a dc motor from any source and need to make any control project but you need its parameters to work, so if one have any information will be thanks
    Quote Originally Posted by iugmoh View Post
    hi all,
    http://www.diyelectriccar.com/forums/
    Some of these guys might have a better clue.
  1. DC to AC convertor
    Last Post: - 6th February 2010, 17:44
  2. Replies: 24
    Last Post: - 1st December 2009, 08:01
  3. from 5v dc to 1.00v dc precise vref 10mA ?
    By phoenix_1 in forum Schematics
    Last Post: - 28th July 2009, 08:11
  4. PIC data along dc line
    By sswcharlie in forum General
    Last Post: - 30th August 2008, 08:38
  5. DC motor parameters ?
    By iugmoh in forum Off Topic
    Last Post: - 28th June 2008, 10:46
