8 servo motor biped
Results 1 to 3 of 3
    Apr 2008
    Default 8 servo motor biped
    Is there anyone who has built a 16F84-controlled 8 servo motor biped like the one in Jon Iovine's PIC book ?
    A video of this robot walking can be seen at the Images SI site.
    I'm having a problem with mine.
    It will initialize in a knee bent foward stance.
    When it goes into its first movement, both ankle servos tilt the robot to the left until the robot falls over. Then no other movement occurs.
    Apr 2008
    Unhappy 8 servo motor biped
    Is there anyone who has built the PIC16F84-controlled 8 servo motor biped in Jon Iovine's PIC book ?
    I have.
    This is the latest problem I ran into:
    The biped starts off by initializing its stance (knees bent forward).
    When it goes into its first movement, both ankles tilt to the left and the robot falls over and then nothing occurs, as far as any other individual servo movements.
    Anyone else run into this problem ?
    I just got to thinking about my problem and had this thought:
    Jon Iovine recommends putting a GOTO HOLD statement after each movement, so you can see the movement and tweak the positioning of the servos if need be. I did that after the first movement, but then got greedy, removed the GOTO HOLD statement after the 1st movement, reprogrammed the chip and tried it again; the same thing happened.
    Is it possible that the GOTO HOLD statement I removed after the 1st movement is still "burned" into the chip ?
    I thought that all the code is erased before it is "burned" again ? or is there a setting I need to check ?
    Quote Originally Posted by rick hardy View Post
    I have.
    <font color = red>Is it possible that the GOTO HOLD statement I removed after the 1st movement is still "burned" into the chip ?</font color>
    If you did not erase the chip prior to programming, As I understand it is possible .
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. saving RCREG to word
    Last Post: - 15th September 2008, 13:51
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 19:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 21:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 18:15
