Which DAC would that be?
Not too many PICs out there have DACs.
Another thought for you...
44.1Khz sample rate * 16 bits * single channel (ignoring stereo for the moment)
705,600 bps shift rate... Doable by a PIC, assuming you use the right crystal and the right baud rate dividers...
88,200 bytes per second total transfer rate from EEPROM to DAC thru the PIC.
Again, doable by a PIC since it's the same thing.
Ok, set up the SPI at the proper bit rate to shift data out of the EEPROM sequentially...Done...
Catch an interrupt every 8 bits to grab byte data from the SPI...
Catch every other interrupt after grabbing 2 bytes to send the 2 bytes out to the DAC.
Is this going to be a serial DAC or a parallel DAC? 16 bit DAC or 8 bit DAC?
Serial DAC...well, your SPI is already tied up grabbing data from the EEPROM, unless you're using a large PIC with 2 SPI modules. So, do you have enough PIC cycles left over to shift that data in and/or out using the firmware? Using Shiftin and/or Shiftout, you aren't going to have a lot of cycles leftover for much at all.
Parallel DAC...Your SPI is still tied up grabbing data from the EEPROM. Do you have enough pins left over to pump parallel data out to the DAC (at minimum a 28 pin PIC with practically no pins leftover to do anything)? Not to mention enough cycles left over to process any other inputs/outputs that your project requires?
I would like to have a sound project based on Norm's project which is great although I didn't test it yet.
I will not use my main pic to handle the job. I will use a dedicated pic to manage the EEPROM->PIC->DAC work. Only one pin of my main MCU will trigger the sound play.
I intend to use a 16 bits serial DAC with a PIC18F452 and a 10MHz Crystal.
I think that sending a 88KB sound file from the eeprom to the DAC is manageable as Norm already did it (with a M25P32 SPI memory at 50MHz). I will try to use 25AA1024 1Mbit 20MHz microchip memory (I say 'try' because I have to calculate to check if, as you say, I will have enough cycles to perform the all the transfers).
I NEVER used SPI and I even don't know how to program the routines. In hardware mode it sounds easier but it is still hazy. I will read Microchip Application Notes and code sample and read Norm's code. I have to make routines as I didn't find dedicated functions in PBP.
It would of course be easier to use Norm's project 'as is' but I would like to create my own application and as I want to use it in a 'commercial' application, I can't just use someone else's work.
