Wanted: Sound chip interfaced with pic
Results 1 to 35 of 35
    xnihilo's Avatar
    xnihilo Guest
    Smile VS1001 sound chip with a pic
    I found an MP3 sound chip, VS1001.
    It can be interfaced with a pic.
    Does someone have Picbasic code for this?
    Thanks anyway
    Quote Originally Posted by xnihilo View Post
    That's an older MP3 chip, been around for quite awhile. Loads, literally hundreds of examples of how to drive the VS1001 chip around the internet. Just a matter of shifting data from one point to the other.
    Question is... do you know how to get an MP3 sound into an eeprom, an external eeprom? 'cause a decent sound bite surely won't fit in any PIC internal eeprom.
    And have you downloaded the datasheet for it yet?
    And have you even tried the SOUND command yet?
    I have a Winbond ISD4002 I intend to hook to a PIC (someday!). This has SPI interface, and can have multipule messages. It is available with different recording times. All you have to do is connect a microphone and a speaker, so they say!
    xnihilo's Avatar
    xnihilo Guest
    Quote Originally Posted by jderson View Post
    Have you more info or example? (code/intefacing). You need a special hardware and/or software to set your sounds.
    xnihilo's Avatar
    xnihilo Guest
    I id NOT find a good interfacing example Mr SkimaskKnowsEverytging.
    Yes I have the datasheet.
    Yes, I am using to create a placeholder for the gunshot sound in my code but it sucks.
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. newbe looking for PIC advice
    By Mad Professor in forum General
    Last Post: - 27th May 2009, 08:56
  3. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  4. AT keyboard interfaced to a PIC
    By languer in forum Schematics
    Last Post: - 28th December 2005, 06:11
  5. Battery Backup with PIC controlling switch
    By Dwayne in forum Schematics
    Last Post: - 27th December 2003, 14:16
