Someone Posts a Code Example, Then What?
Results 1 to 6 of 6
    Dec 2005
    I don't think I have schematics for each that use the PIC12F629 but my web page does have schematics of the basic circuits using similar chips (although they may use different pins). See...For the transdmitter, I used a chip with ADC so I can modify the output to signal a low battery. If you are not interested in that, use the PIC12F629 and omit the connection to pin 6. Because I wanted to maximize battery life, the transmitter is powered by the data signal so there is no transmitter drain when idle.
    For the receiver circuit you can use a PIC12F675 or the PIC12F683, as shown, if you want to measure received signal strength using an ADC pin (code will need modification). Otherwise, a PIC12F629 is fine.
    NOTE: While the code uses a protocol developed about 40 years ago by NEC for IR remote control (TV, etc.), it's being used here for RF (as X-10 has used it for for nearly 40 years). If you want to use it with IR it's a bit different for both transmitting and receiving.
    Dec 2007
    Hey Dave,
    I plan on using IR in the future but for the moment i would like to get the RF working, the RS232 portion of the reciever is also something i would like to play with so the code you have posted is a perfect start.
    Thanks again,
    Jeremy
    Dec 2005
    The primary differences for IR are that you need to modulate the transmitter with the IR carrier frequency (usually 36-40kHz) and IR receivers are active low whereas RF receivers are active high. If you wander about my website you'll find a few schematics that may help. You can find more specific schematics on Bruce Reynols website...Make sure that you are using the latest version of Code Studio. I believe the sample code was written for use with MPASM. If you want to use the meLabs PM assembler, you need to change the fuse config settings - there's a thread here that details the different syntaxes...
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
