Be helpful otherwise go get a life, have a Beer, etc etc
+ Reply to Thread
Results 1 to 40 of 61
    T.Jackson's Avatar
    T.Jackson Guest
    There's 3 things that make a programmer good.
    1. Reasoning
    2. Terminology
    3. Imagination
    Put simply, "reasoning" is logic. Terminology is knowledge. Imagination is passion.
    You're an expert programmer if you've got a strong strength in all 3 ...
    Trent Jackson
    Jan 2006
    Istanbul
    1. Reasoning
    2. Terminology
    3. Imagination
    Trent Jackson
    Come on TJ,
    Those are what you think.
    You should have started with "I think there are three things ....".
    The word "good" is not a good choice to express whether a programmer is good or not.
    And who determines the level of being "good" for a program or code or programmer?
    In mechanical engineering, or chemical engineering or electrical engineering etc. there are rules and formulas that you are entitled to.
    Those are the law of the nature, no one can change them.
    The engineers in those fields must use those formulas to calculate & built something.
    AND if one day the building collapses, then you can use the expression of "good" or "bad" for the engineering.
    However, when it comes to programming, there are no rules, just "shoulds" and "should nots"; you design and then create your laws, rules and the nature.
    There is always a better code writer TJ, you know it very well.
    If your code works, and it does what you need, whether in two lines or 10 lines then it is good enough for the application. And if you are happy with it, then it is good enough programming.
    Therefore, there is no good programmer TJ, but good enough programming.
    Your three things are something you think.
    T.Jackson's Avatar
    T.Jackson Guest
    Well ...
    They're my original thoughts anyhow. I've read 3 books and I'm a quarter of my way through a bachelor’s degree in Information Technology. Plus I have 5 years experience as a programmer.
    Trent Jackson
    Trent does make a good point
    Need to be able to think logically to solve problems.
    Need to have knowledge in the system you are working with and of what ever the program is to accomplish.
    Need to have an imagination to put it all together.
    And like sayzer said.
    IMHO
    On another forum, one user have the following signature..
    'Good enough is perfect'
    and then ...
    http://paulbuchheit.blogspot.com/200...nough-and.html
    Trent Jackson
    Could ya speak up a bit! I can't hear you very well from all the way up there!
    I may be incorrect but I believe this thread has totally lost its original topic of discussion.
    People helping people is what this forum is all about is it not? If I have written/modified some code that can be of use to someone they are by means free to use it. I would like nothing better than to know that I helped someone out and that they appreciated it. It's all part of learning I think. I personally prefer the hands approach to learning things. I am quite certain there are numerous others much like myself here also. Reading a smart-ass reply does nothing but consume peoples times and discourage them from posting and sharing future postings. This however is just my 2 cents worth.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Did everyone go out for BEER ?
    By Archangel in forum Off Topic
    Last Post: - 13th July 2008, 02:39
  3. Worst day of my life
    By brid0030 in forum USB
    Last Post: - 12th March 2008, 22:27
  4. EEPROM life expectancy?
    By muddy0409 in forum General
    Last Post: - 1st May 2007, 12:44
  5. Any chance of Life being easy?
    By josegamez in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2006, 20:52
