PLC Interfacing with PIC
Results 1 to 16 of 16
    Dec 2007
    Default thank you so much
    Thank you so much for all your advise. I will try them. Maybe i can use zener diodes to replace LM7805. I appreciate your effort and time.
    New Zealand
    Just use a resistor! The input pin is limited to vcc so a resistor works quite well and is very cheap and simple - if the output of your PLC is left floating you may have to tie it down with another resistor. I've used a resistor straight into a PIC from 240Vac for sensing the zero crossing to synchronize firing a TRIAC (I think I used some where in the region of 200k). It seems so wrong I know, but it really works well and is simple.
    New Zealand
    Just make sure with yr resistor you don't exceed 20mA - try keep it down to 1-2mA
  1. Interfacing DS1603 to PIC 16F877
    By hackableFM in forum mel PIC BASIC Pro
    Last Post: - 25th February 2009, 22:37
  2. Interfacing two PIC micros
    By sajid in forum General
    Last Post: - 26th May 2007, 07:58
  3. Motor Control PLC with a PIC
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2006, 08:59
  4. Serial Pic to Pic using HSER
  5. PIC vs PLC (programmable logic controller)
    By pondindustrial in forum Off Topic
    Last Post: - 17th December 2004, 22:11
