I've used quite a few Opto22 modules. (Opto's plant is just across the street from me.) They work well, but check the spec sheet on timing, if you need high speed.
On my last project, I used Grayhill's Opto22 pin-compatible modules, and saved quite a bit of money. They worked just as well as Opto's.
