PLC Interfacing with PIC
Results 1 to 16 of 16
    Jan 2006
    Toronto
    How would a 7805 be a problem? I would think it would actually clean the signal with a cap or two.
    The cap is even worse. It can hold the input signal in a given state and cause false sensor readings. When it comes to PLCs, do it right and use optos for input and either optos or solid state relays for the outputs. The last thing you want is to go through the programming over and over trying to figure out why your timings are wrong.
    Mar 2005
    Iowa, USA
    If you're looking for an "off the shelf" solution (which most of us are not) look at opto22 modules or similar.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Sep 2007
    USA, CA
    I've used quite a few Opto22 modules. (Opto's plant is just across the street from me.) They work well, but check the spec sheet on timing, if you need high speed.
    On my last project, I used Grayhill's Opto22 pin-compatible modules, and saved quite a bit of money. They worked just as well as Opto's.
    Dec 2007
    Default thank you so much
    Thank you so much for all your advise. I will try them. Maybe i can use zener diodes to replace LM7805. I appreciate your effort and time.
    New Zealand
    Just use a resistor! The input pin is limited to vcc so a resistor works quite well and is very cheap and simple - if the output of your PLC is left floating you may have to tie it down with another resistor. I've used a resistor straight into a PIC from 240Vac for sensing the zero crossing to synchronize firing a TRIAC (I think I used some where in the region of 200k). It seems so wrong I know, but it really works well and is simple.
    New Zealand
    Just make sure with yr resistor you don't exceed 20mA - try keep it down to 1-2mA
  1. Interfacing DS1603 to PIC 16F877
    By hackableFM in forum mel PIC BASIC Pro
    Last Post: - 25th February 2009, 22:37
  2. Interfacing two PIC micros
    By sajid in forum General
    Last Post: - 26th May 2007, 07:58
  3. Motor Control PLC with a PIC
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2006, 08:59
  4. Serial Pic to Pic using HSER
  5. PIC vs PLC (programmable logic controller)
    By pondindustrial in forum Off Topic
    Last Post: - 17th December 2004, 22:11
