PLC Interfacing with PIC
Results 1 to 16 of 16
    Dec 2005
    So Cal and loving it
    Hello skian85 and Welcome,
    The opto's are a good way, a perhaps simpler and cheaper way is to use a 78L05, regulator.They are in a TO92 package 3 wires.
    Hah! I would never have thought about using a 7805 for that purpose..... Nice!
    I will never forget this one, hehehe
    | PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
    Sep 2007
    USA, CA
    Quote Originally Posted by locko View Post
    It's cute, but with a PLC, I would go with the opto isolators. PLC's often switch relays and other noisy things in noisy environments, so you are probably much better off making sure you get a clean signal to your PIC.
    Quote Originally Posted by tenaja View Post
    How would a 7805 be a problem? I would think it would actually clean the signal with a cap or two.
    Sep 2007
    USA, CA
    It will clean up one a bit, but PLC's are typically used in the most notoriously dirty environments, from an electrical standpoint. It may work for many applications (i.e. a quick & dirty fix), but an opto-iso is a better choice.
    Dec 2007
    Cd. Juarez, Mexico
    Hi, I think a 7805 could be a solution for the output from the PLC to the PIC, but what about the output from the PIC to the PLC?
    I still prefer the optocoupler solution for both sides.
    Alfredo
    Jan 2006
    Toronto
    Please don't go with the 7805. I tried this and was bad idea, i couldn't hunt down a counting problem i was having and it turned out to be the regulator. Regulators will only work if your inputs don't change very fast, the regulators are kinda slow. I used it to interface to a gear sensor and was losing a lot of pulses. Def stay with the optos. Good isolation and reliable.
    Does your PLC have some kind of monitor function from a serial port? You could just hook up the PIC to the PLC serially then and just process the monitor codes the PLC sends out.
    Or are you planning to use the PIC to watchdog the PLC?
    Otherwise, using optos is the best way. All the signals to the PIC would be inputs, because you are monitoring the inputs and outputs of the PLC. So the optos would be all connected the same way, with the LED connected to the PLC signals on the anodes through a current limiting resistor, and gnd on the cathodes. Pick your resistor so you get minimum on current for the LED with about 5VDC and less than maximum with 24VDC. Remember that the LED has a forward voltage that needs to be subtracted before you calculate the current though the resistor. On the PIC side, connect the emitter to gnd and the collector to +5VDC though a 500-1k ohm resistor. Connect the PIC pin between the resistor and the opto collector. This will create an inverter, so remember to invert the signals in the PIC code.
    Tim Barr
    Jan 2006
    Toronto
    The cap is even worse. It can hold the input signal in a given state and cause false sensor readings. When it comes to PLCs, do it right and use optos for input and either optos or solid state relays for the outputs. The last thing you want is to go through the programming over and over trying to figure out why your timings are wrong.
    Mar 2005
    Iowa, USA
    If you're looking for an "off the shelf" solution (which most of us are not) look at opto22 modules or similar.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Sep 2007
    USA, CA
    I've used quite a few Opto22 modules. (Opto's plant is just across the street from me.) They work well, but check the spec sheet on timing, if you need high speed.
    On my last project, I used Grayhill's Opto22 pin-compatible modules, and saved quite a bit of money. They worked just as well as Opto's.
    Dec 2007
    Default thank you so much
    Thank you so much for all your advise. I will try them. Maybe i can use zener diodes to replace LM7805. I appreciate your effort and time.
  1. Interfacing DS1603 to PIC 16F877
    By hackableFM in forum mel PIC BASIC Pro
    Last Post: - 25th February 2009, 22:37
  2. Interfacing two PIC micros
    By sajid in forum General
    Last Post: - 26th May 2007, 07:58
  3. Motor Control PLC with a PIC
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2006, 08:59
  4. Serial Pic to Pic using HSER
  5. PIC vs PLC (programmable logic controller)
    By pondindustrial in forum Off Topic
    Last Post: - 17th December 2004, 22:11
