bizarre problem 16f628-20/P -?
Results 1 to 11 of 11
    May 2007
    Republic Serbia
    Well, again, let's see some code, some configuration information, what kind of programmer, software, maybe some schematic information, power supply, anything, etc.
    @ DEVICE pic16F628, HS_OSC
    ' ---- High Speed Oscilator
    @ DEVICE pic16F628, WDT_OFF
    ' ---- Watchdog Timer=OFF
    @ DEVICE pic16F628, BOD_ON
    ' ---- Brown-Out Detect
    @ DEVICE pic16F628, LVP_OFF
    ' ---- Low-Voltage Programming=OFF
    @ DEVICE pic16F628, MCLR_ON
    ' ---- Reset Pin=Internal
    @ DEVICE pic16F628, PWRT_ON
    ' ---- Power-On Timer=Disabled
    @ DEVICE pic16F628, CPD_OFF
    ' Data Memory Code Protect
    ' Set to CPD_OFF for Development Copy
    @ DEVICE pic16F628, PROTECT_OFF
    ' Program Code Protection
    'MCLR pin is pullup at 5V via 4K7
    'external XTAL @20MHz and two cap (I was probe from 10pF to 27pF)
    'portb.1 to led via 330 ohm and 330 ohm to GND (led is low current green)
    'when I put in same socket PIC 16F628-04/P and change XTAL to 4MHz and 2x27p LED
    'blinky OK and if I change in that socket 16F84A-20/P and use XTAL 20MHz and 2x27p
    'it blinky 100% OK. THAT MEAN THAT PROTO PCB is OK ........
    'these code is for 16F628-20/P @20MHz HS osc
    'programmer is EPIC programer and work fine for me ;-)
    define osc 20
    CMCON = 7          ' PortA = digital I/O
    VRCON = 0          ' Disable A/D Voltage reference
    low portb.1
    pause 250
    loop:
    high portb.1
    low portb.1
    goto loop
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Something to try ....
    remove (carefully unsolder?) the LED and see if pin goes high low high with a meter. If this works then reconnect up your LED and add decoupler Cap close to Vdd (10uF or similar).
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    May 2007
    Republic Serbia
    Cool
    Quote Originally Posted by paul borgmeier View Post
    Thank's friend,
    I was probe many trick's nothing want to work,simply I am confused....
    Is some posibility to someone manufacture clone of PicMicro or something same ???
    On first look it same signature like other on other PicMicro what I have in colection..
    It is not important to me to I make it work and sale in some my hardware but it very interest for me to I find what is it why...etc.
    I was probe to config it with internal osc at 4MHz and same problem too.
    Now I go to get frquency meter and I will post if is osc activity on it ?!
    Quote Originally Posted by phoenix_1 View Post
    Thank's friend,
    Hi Phoenix,
    I am having a little trouble with the use of the word "probe" As I understand this word, it is when you put the "test probe" of your meter on a voltage source or when your doctor pokes you looking for a tender spot, if you would please elaborate a little you would be helpful.
    As to your code: Verify it is a 16F628 and not a 16F628A correct?
    Now,
    incorrect, cmcon = 7 ' turn off analog comparators
    '<font color=red>it blinky 100% OK. THAT MEAN THAT PROTO PCB is OK ........</font color>
    Proto boards are loss-ey, which is to say, using them is much like installing a bunch of unwanted capacitors, the connections are often poor. If you are using crystals instead of resonators, you might try reducing/not increasing the value as you go up in frequency, even try it without the caps (on the breadboard only), as I said before, the breadboard adds a bunch of extra capacitance to the circuit. Yes it is possible you got a hold of a counterfeit
    PIC, although somewhat unlikely. Keep your wiring to the crystal very, very short. Anything attached to the crystal ports will load down the oscillator and keep it from working.
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. Strange problem with Serin/Serout on 16F628
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 01:16
  3. Replies: 3
    Last Post: - 12th February 2007, 19:32
  4. 16F628 problem
    By Brown in forum mel PIC BASIC
    Last Post: - 6th May 2005, 20:56
  5. 16F628 on-chip eeprom problem
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 4th March 2004, 08:43
