USB Keyboard input don't work!!! Please Help
Results 1 to 18 of 18
    Jan 2008
    Default I dont understand
    How many bytes USB keyboard receives? When? Where is LED's data stored?
    Oct 2003
    Australia
    Cool
    Ok Faaktoo
    Firstly the caps, numlock status are sent as bits in byte zero sent from the pc. These are are always sent from the pc on every DoUSBin service.
    ' BYTE 0 - LEDS STATUS (USBIN, OUTPUT REPORT)
            'BIT 0 = NUM LOCK
            'BIT 1 = CAPS LOCK
            'BIT 2 = SCROLL LOCK
            'BIT 3 = COMPOSE
            'BIT 4 = KANA
            'BIT <5:7> = NOT USED PADDED DATA
    If you want to display the status of the caps, num lock, scroll lock on your pic than you could put some LEDs on a port and assign var to them , example:
        ' the leds
        NUM                 VAR PORTB.0
        CAPS                VAR PORTB.1
        SCRL                VAR PORTB.2
    If this bit is 1, the led is on. If it is 0, the led is off.
    Than in your main program your can display the satus of the scroll lock etc in a DoUSBin routine.
    Example
    DoUSBIn:
    '   Check and receive data from the USB bus
        USBBufferCount = USBBufferSizeRX                ' RX buffer size
        USBService                                      ' keep connection alive
        USBIn 1, USBBufferin, USBBufferCount, SHOWLEDS
    SHOWLEDS:
        NUM  = USBBufferin.0(0)    ' num lock
        CAPS = USBBufferin.0(1)    ' Caps lock
        SCRL = USBBufferin.0(2)    ' Scoll lock
    To display the status of the Caps lock, Num lock etc on the keyboard (ie simulate the key press on a button connected to your pic) just send the key number for the caps, num lock etc as part of your DoUSBout Bytes.
    For caps lock it is $39
    For scroll Lock it is $47
    For num lock it is $53.
    BTW, You still haven't said please yet.
    Why is this so hard to
    find,
    download
    and use a USB sniffer as suggested many time here?
    HHDSoft USB Monitor is one of the thousand one available.
    Who's your daddy huh?
    Talking
    Quote Originally Posted by Squibcakes View Post
    $139 for the code? Wow!
    All this time i thought i would make $D3
    Oct 2003
    Australia
    Thumbs up
    Hahaha.
    Very funny guys.
    Have a great weekend!
    Jan 2008
    Default Hello dear members!!!
    I find the where is my firs problem. In KBDDESC.ASM. This file is designed one way only. I put one more endpoint and my DOUSBIN it start to work (finaly).
    I'm sory for my English and thank you very mutch for the help.
    Ha, I did it. I'm the men for the new job
  1. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  2. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 17:10
  3. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 01:04
  4. Replies: 3
    Last Post: - 10th April 2008, 11:02
  5. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
