Now to something completely different
Results 1 to 16 of 16
    Hi, the irda signal is not modulated; so, you first need to get rid of the TSOP-IR-Receiver.
    Adding irda capability to a PIC could be achieved a number of ways. Microchip themselves have irda codec solutions. Or, look up www.sirpic.com. The guy there, Ravi, specializes in Micro-to-irda solutions in varying degrees of customization. At this site, you'll also find a software-only irda implementation for PICs contributed by another person.
    Anand
    Ted's's Avatar
    Ted's Guest
    Anand
    Or modulate the signal. This is what I want to do. Being dependend on light situations has always been the greatest drawback of irda.
    Is there a sorce code on his site? I couldn't find any...
    Ted's's Avatar
    Ted's Guest
    I am using a vb-clone for palm programming.
    The only option is to use IrDA.
    If I use IrDA,open the connection and send the value 3211 using a baudrate of 38400 and having the TSOP attached to the pic, what should I receive and how do I convert it back to the value via pbp?
    Please no links this time. I want to see this problem solved step by step so I can create a code suitable according to this example.
    Ted, here are my views. Consumer IR, which uses modulation, has range, but cannot handle large data flows; that is why irda is not modulated, to enable a relatively higher bandwidth.
    You cannot, therefore, modulate and demodulate the raw irda at each end and expect good results (unless you design a complex data buffering system to be stuck in between).
    If you must use irda, you will have to accept the raw irda distance limitations.
    Ted's's Avatar
    Ted's Guest
    There is no need for high bandwidth.
    There is a need for emulating the 38khz carrier frequency using IrDA as IrDA is the only way to access the IR Port.
    What I found is that using a baudrate of 38400 makes the PIC-Device understand something(I made a LED flash each time the PIC recieves a High-Low and Low-High-change) but I cannot decode it as I don't understand it. It is no real rs-232-code.
    You can help me by sharing pseudo-code for my Palm Programme and PBP-Code for the receiving part.
    Ted's's Avatar
    Ted's Guest
    I address this to all readers:
    Ted's's Avatar
    Ted's Guest
    To the other users: Note that there are some closed source Palm remote control emulators being proof for doability.
    There is still a want for a solution.
    Sorry, there must have been an error of some kind.
    Many posts of the same message appeared.
    Also edited the last message, since it no longer applied.
    Thanks, Darrel.
    I have no idea why my message got posted repeatedly.
    I'm sorry for the inconvenience caused.
    Anand
  1. PBP projects for R/C models
    By malc-c in forum Code Examples
    Last Post: - 21st October 2016, 13:56
  2. EasyHID and USB for Newbies??
    By Squibcakes in forum USB
    Last Post: - 26th November 2015, 23:41
  3. completely incompetent
    Last Post: - 10th February 2006, 22:07
