Basic Compiler won't work with Vista
Results 1 to 5 of 5
    Dec 2005
    So Cal and loving it
    Couple of things to keep in mind with Vista....
    The vista UAC... the program files folder can only be written to by a program with administrator rights. If you keep your pic files in your documents folder you should have more luck.
    Also if you want MCS to launch a programmer that lives in the program files foder, MCS will have to be ran as administrstor.
    The point about the long file names can be an issue with some programs/programmers and I also came across a compiler that could not launch because the path had spaces in it.
    Take a look at my signature for what I am running with no problems/work-arounds.
    Paul
    | PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
  1. Loop with two motor and 2 sensors
  2. PIC BASIC Compiler for ARM machines?
    By stone20008 in forum General
    Last Post: - 22nd August 2008, 08:14
  3. Visual Basic 6 and Vista
    By cooksydesign in forum Off Topic
    Last Post: - 11th February 2008, 14:54
  4. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  5. Replies: 5
    Last Post: - 17th January 2006, 20:26
