"Function Generator" Triangular Wave disturb
Results 1 to 10 of 10
    Mar 2006
    INDIA
    Default "Function Generator" Triangular Wave disturb
    Every Triangular pulse is disturb.
    ' chip - PIC18F4620
    @ __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
    @ __CONFIG    _CONFIG3H,  _PBADEN_OFF_3H & _MCLRE_ON_3H
    DEFINE OSC 40
    INCLUDE "modedefs.bas"
    include "My_EasyPIC4_LCD.bas"
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 2
    ADCON0 = %00001111
    ADCON1 = %00001011
    B0 VAR WORD
    B1 VAR WORD
    B2 VAR WORD
    B3 VAR WORD
    B4 VAR WORD
    B5 VAR WORD
    B6 VAR WORD
    C0 VAR BYTE
    C1 VAR BYTE
    PAUSE 1000
    LCDOUT $FE,1
    PAUSE 1000
    TRISB=$00
    TRISD=%11110000                'Bits-4,5,6,7 Inputs, & Bits-3,2,1,0 Outputs of PORTD
    Keyscane:
             LCDOUT $FE, 1
             LCDOUT "Scanning"
            IF PORTD.4 = 1 THEN SquareWave
            IF PORTD.5 = 1 THEN TriangularWave
            IF PORTD.5 = 1 THEN SineWave
            GOTO Keyscane
    SineWave:   IF PORTD.5 = 1 THEN SineWave              'Wait for release button
    	    TRISD=$00                                 'Make PortD an Output Port
                LCDOUT $FE, 1
                LCDOUT "Sine-Wave"
                pause 200
                C0=0                                            'Initialize the Sine Angle
    Init_Sine:  TRISD=$00                                       'PortD an Output Port
                PORTD=((((SIN C0)+127)/10)*5)+50            '(+127) Removes the Negative Values
                                                            'Ampitude (Peak Value) = 1/2 of 5/10
                                                            'of the Maximum Output Voltage
                                                            '50 Represents the DC Offset
                                                            'DC Offset = 1/2 of 50/255
                                                            'The DC Offset is Measured between Zero
                                                            'and the Negative Peak of the Sinewave.
                                                            'To Obtain the Maximum Value, Change
                                                            'Both the 5 and the 10 to a 1.
            pauseus 1                                       'Pause Allowed between Angle Changes
                                                            'This will create, approximately, 100 Hz
            C0=C0+1                                         'Increments the Sine Angle by 1 out of 255
            GOTO Init_Sine
    SquareWave:   IF PORTD.4 = 1 THEN SquareWave
    	      TRISD=$00
                  LCDOUT $FE, 1
                  LCDOUT "Square-Wave"
                  PAUSE 200
    Init_Square:  TRISD=$00                                 'PortD an Output Port
                  PORTD=0                                   'Square-Wave at PortD
                                                            'Starting with Decimal 0 out of 255
                                                            'of the Maximum Output Voltage.
                   PAUSEUS 2                                'The Smallest PAUSE Allowed is 5 micro-seconds.
    							'approximately 46KHz.
                   PORTD=255
                   PAUSEUS 2
                   GOTO Init_Square
    TriangularWave:   IF PORTD.5 = 1 THEN TriangularWave
    		  TRISD=$00
                      LCDOUT $FE, 1
                      LCDOUT "Triangle-Wave"
                      PAUSE 500
    Init_Triangluar:  TRISD=$00                             'PortD an Output Port
                      PORTD=0                               'Triangle-Wave at PortD
                       PAUSE 1                              'The Smallest PAUSE Allowed is 1 micro-second.
                             		                '10 micro-seconds, in 1 micro-second steps,
    						        'approximately, 40KHz.
            PORTD=25
            PAUSEUS 1
            PORTD=50
            PAUSEUS 1
            PORTD=75
            PAUSEUS 1
            PORTD=100
            PAUSEUS 1
            PORTD=125
            PAUSEUS 1
            PORTD=150
            PAUSEUS 1
            PORTD=175
            PAUSEUS 1
            PORTD=200
            PAUSEUS 1
            PORTD=225
            PAUSEUS 1
            PORTD=255
            PAUSEUS 1
            PORTD=225
            PAUSEUS 1
            PORTD=200
            PAUSEUS 1
            PORTD=175
            PAUSEUS 1
            PORTD=150
            PAUSEUS 1
            PORTD=125
            PAUSEUS 1
            PORTD=100
            PAUSEUS 1
            PORTD=75
            PAUSEUS 1
            PORTD=50
            PAUSEUS 1
            PORTD=25
            GOTO Init_Triangluar
    Wink
    RTFM ...
    What is the minimum PASEUS lenght vs frequency ???
    Answer is in the Manual ...
    PS ... may be some asm lines to include ... but it's me !!!
    PAUSEUS 1 should be fine for 1uS running at 40MHz.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Book says 2us minimum above 25Mhz on an 18F.
    Latest PBP manual. Page #113 states 40, 48, 64MHz OSC, "PIC18Xxxxx only" is 1uS.
    25, 32, 33MHz is 2uS.
    -Bruce
    tech at rentron.com
    Mar 2006
    INDIA
    Smile
    Hi
    Thanks sir Bruce.
    I am in fault.
    i wrote Pause 1 instead of PAUSEUS 1 after "Init_Triangluar:"
    Thanks skimask and Acetronics.
    I was reading manual. and sir bruce solved .......
    There are no enough mind after bonding of straingage on 50 torque sensor in a day ....
    Oh...
    Thanks again, its working.
    a little spike here,may be ?
    PORTD=200
    PAUSEUS 1
    PORTD=225
    PAUSEUS 1
    PORTD=255 ... should not be 250 ???
    PAUSEUS 1
    PORTD=225
    PAUSEUS 1
    PORTD=200
    did you try :
                       PAUSEUS1                              'instead of PAUSE 1
    PS : didn't notice the 40Mhz Define ... sorry !
    Good point! Another update/change I hadn't noticed
  1. how to generate triangular wave.....
    By kvrajasekar in forum mel PIC BASIC Pro
    Last Post: - 11th September 2008, 19:16
