PicBasicPro+MicroCode studio plus and ICD debugging
Results 1 to 13 of 13
    May 2008
    Smile Serial connection
    Connection are good on serial!
    I can get the 628 to blink led without connecting to max232 with that code....
    ' Example program to blink an LED connected to PORTA.0 about
    ' once a second
    'DEFINE LOADER_USED 1
    'DEFINE OSC 4
    trisA.0 = 0
    x var byte
    led var porta.0
    loop:
    x=1 ' Turn on LED connected to PORTB.0
    led=x
    Pause 500 ' Delay for .5 seconds
    x=0 ' Turn on LED connected to PORTB.0
    led=x ' Turn off LED connected to PORTB.0
    Goto loop ' Go back to loop and blink LED forever
    To get RX and TX working on 628 should i put line in code to get it to send and receive or ICD complile does it for me....
    May 2008
    Default Microcode studio plus
    I do select the right COM to run program....witch is COM9 for me....is a PCMCIA card to RS232.
    May 2008
    Default Desktop image of MicroCode ERROR
    Quote Originally Posted by michel View Post
    Looks to me like the fix for your problem is right there in the error message...
    May 2008
    Unhappy I did try It!
    Bruce told me that I don't need DEFINE LOADER_USED 1. I have tried it with it an doesn't work.
    Is the led supposse to blink when programmed with ICD complile and program?
    Tanks again...
    DEFINE LOADER_USED 1 is only needed when using a boot-loader.
    No. It should only blink when you are running ICD.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    May 2008
    Default Breadboard is working
    Hi Bruce!
    I finally got it.....on the breadboard....it's a beginning
    What was wrong:
    On the shematic from Microcode studio plus, took off the link from (db9, pin4) to (max232, pin 8); (max232, pin 9) to resistor 100 Ohms.
    Here is the code:
    trisA.0 = 0
    x var byte
    led var porta.0
    ENABLE DEBUG
    loop:
    x=1 ' Turn on LED connected to PORTA.0
    led=x
    x=0 ' Turn on LED connected to PORTA.0
    led=x ' Turn off LED connected to PORTA.0
    DISABLE DEBUG
    NOW I HAVE TO FIGURE OUT THE PCB....
    The 628 transmit only 20 seconds after the power is turned on....
    Attached here is the pcb layout....
    Tanks again Bruce!
