Before you can get ICD working you need to make sure you have a good serial connection.
If you can send/receive serial data between the PIC & PC it should work fine with the ICD.
If not, then you'll need to fix that first.
Connection are good on serial!
I can get the 628 to blink led without connecting to max232 with that code....
' Example program to blink an LED connected to PORTA.0 about
' once a second
'DEFINE LOADER_USED 1
'DEFINE OSC 4
trisA.0 = 0
x var byte
led var porta.0
loop:
x=1 ' Turn on LED connected to PORTB.0
led=x
Pause 500 ' Delay for .5 seconds
x=0 ' Turn on LED connected to PORTB.0
led=x ' Turn off LED connected to PORTB.0
Goto loop ' Go back to loop and blink LED forever
To get RX and TX working on 628 should i put line in code to get it to send and receive or ICD complile does it for me....
I do select the right COM to run program....witch is COM9 for me....is a PCMCIA card to RS232.
Bruce told me that I don't need DEFINE LOADER_USED 1. I have tried it with it an doesn't work.
Is the led supposse to blink when programmed with ICD complile and program?
Tanks again...
DEFINE LOADER_USED 1 is only needed when using a boot-loader.Bruce told me that I don't need DEFINE LOADER_USED 1. I have tried it with it an doesn't work.
No. It should only blink when you are running ICD.Is the led supposse to blink when programmed with ICD complile and program?
