19200 Baud In Pic16f690
Results 1 to 11 of 11
    May 2008
    Default Filter Power Supply
    Quote Originally Posted by simpsonss View Post
    hi MARGARITA,
    seems like it works with 20 Mhz, i would like to ask a question. I'm facing the same problem as you too. everything works find with 4Mhz OSC but no for 20 Mhz OSC. what u mean by parallel with power supply? i should i connect the circuit?
    thanks.
    I FOLLOW INSTRUCTIONS FROM JOE, SKIMASK AND PUT 1000MF CAPACITOR IN PARALLEL WITH 5 VOLTS SWITCHING POWER SUPPY, (SOME ARE POOR FILTERED ) MY WAS ONE.
    AND UNTIL NOW MY PROJECT WORKS FINE.
    Quote Originally Posted by MARGARITA View Post
    1,000 µF filters are enough to take the ripples off the ocean, I bet your circuit stays powered for hours after unplugging the power supply. What you do need, is a .01 µF , that's point zero one µF near your PIC connected to the power and ground pins, these allow radio frequency noise to get shorted out, resulting in "Clean" DC power to your chip. Those 1000 µF would be great in a high end audio amplifier to filter and act as a backup supply when big power surge requirements arise. Might be you were thinking 1000 PF caps ?
    May 2008
    I Know, but with .1 mfd. I have trouble and with 1000mfd. works ok.
    Last Post: - 8th March 2010, 20:58
  2. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 02:17
  3. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 22:41
  4. 16F877A serin problem with baud rate 19200
    By leemin in forum Serial
    Last Post: - 31st July 2005, 09:45
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 16:48
