MSF receiver module (analogue but with data pins available)
Results 1 to 4 of 4
    May 2008
    Seeing there is no edit button on this and I cant change it
    Does anyone know if the msf and dcf data is the same?
    What I've discovered "so far" is that the DCF signal outputs THIS:
     Bit    Name    Description        Comment
    0-14           Reserved           Coding to requirement
    15     R       Send antenna       0 = Standard antenna / 1 = Reserve antenna
    16     A1      Announcement 1     1 = Next hour a Daylight Saving Time (DST) change occurs
    17     Z1      Time Zone bit 1    0 = Winter / 1 = Summer (DST)
    18     Z2      Time Zone bit 2    0 = Summer / 1 = Winter (usually the opposite of Z1)
    19     A2      Announcement 2     1 = Next hour an extra second is inserted (leap-second)
    20     S       Startbit           Always 1, startbit coded time information
    21-27          Minutes            7 bit, BCD, LSB first (00...59)
    28     P1      Parity bit 1       Even parity for all received bits from the minutes
    29-34          Hours              6 bit,BCD, LSB first (00...23)
    35     P2      Parity bit 2       Even parity for all received bits from the hours
    36-41          Day of the month   6 bit, BCD, LSB first (01...31)
    42-44          Day of the week    3 bit, BCD, LSB first (1 = Monday...7 = Sunday)
    45-49          Month 5 bit,       BCD, LSB first (01...12)
    50-57          Year 8 bit,        BCD, LSB first (00...99)
    58     P3      Parity bit 3       Even parity for all received bits from the date
    i'm guessing the bit numbers above are whats transmitted in those actual seconds?
    While the MSF receiver module I have (and want to use) the only info I have to the outputs are:
     Taken from the PDF file the ONLY info relating to the data output pins:
    Serial Output
    This port can be used for connecting external units, like. digital displays.
    Available information:
     Actual year
     Actual month
     Actual day
     Actual day of the week
     Actual hour [12h]
     Actual AM/PM
     Actual minute
     Actual second
    The transmition always happens on the begining of every hour, at
    HH:00.00,500 and takes 44 ms.
    Additional transmitions will happen after „first receive“, „forced receive“ und „auto
    receive“ and after any correction of the hands was necessary.
    Specification Date: 09.03.2005
    MSF RC_wallclockDO_Specification
    2.7.1. Format of data
    Nr. Describtion Format Numbers Explanation
    1 daylow   BCD 00 - 31 Lower byte of actual day
    2 dayhigh  BCD 00 - 31 High byte of actual day
    3 dayofweek HEX 1 - 7 Day of the week, 1 = monday
    4 month    HEX 1 - 12 Actual month, 1 = January
    5 yearlow  HEX 00 - 63 Actual year, 14H = xx20
    6 yearhigh HEX 00 - 63 Actual year, 14H = xx20
    7 minutelow  BCD 0 - 9 Actual minute, 0 - 9
    8 minutehigh BCD 0 - 5 Actual minute, 10 -50, 0xxx = AM, 1xxx = PM
    9 hour HEX 0 - 11 Actual hour
    10 secondlow  BCD 0 - 9 Actual second, 0 - 9
    11 secondhigh BCD 0 - 5 Actual second, 10 -50
    The transmition is serial, sychronized to a clock-frequency of 1 kHz. The clock frequency is
    also available on the port.
    Timing diagram:
    clock pin … 1
    data pin ... 2
    First nibble Second nibble Third nibble Fourth nibble ...
    daylow = 0101B =5 dayhigh = 0010H =2 dayofw. = 0011H =3 month = 1011H =11 ...
    Beispiel: 25. Nov. Mittwoch
    Example: Nov. 25th Wednesday
    I've got an example of a basic program to decode the German DCF signal but it's in proton basic while I'll be using picbasic pro, which isn't a problem I can figure out how to convert it ok
    What i could do with some help on is, any ideas what bits I need to change in the code to get the msf module decoding?
    i.e the main differences I need to look out for or work on changing
    I've never done anything with clocks before, and never used a serial input to a pic either so any ideas are welcome
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
