General digital thermometer question Thermistor
Results 1 to 6 of 6
    Quote Originally Posted by Neosec View Post
    I'm in the process of doing a thermostat project and have been looking over Digital Thermometer schematics that use thermistors.
    Or just make it easy on yourself and use a DS1820.
    May 2008
    I considered a DS1820 but was concerned about the 1-wire network immunity to noise... I want to have at least 5 temperature sensors 3 indoor, two of which will be up to 200 feet from the PIC probably running along side Romex 120v AC lines. An outdoor sensor and a sensor in a thermowell in a boiler ~180 Deg.F. Thermistors are industry standard in a boiler so I didn't want to reinvent the wheel. And as for the longer runs I just figured the thermistor lines could be filtered with some caps since they're DC so noise would be less of a problem. I guess adding a buffer will provide a more robust signal. Thanks... I'll look into it a bit more now that I know what to look for.
    Sep 2005
    Campbell, CA
    I have successfully used the Microchip MPC9701. Since it has an analog output, you can run the signal 50' or more. Just use a low-pass filter (2K in series, .1uF to GND) with the A/D input and average 16 samples with a 1mSec delay between samples (so that you average out over one complete cycle of 60Hz). The output is linear with temperature (unlike thermistors), and doesn't need calibration. Cheap, too.
    Charles Linquist
    LM34 or LM35 will work too. A cap from signal to ground for longer distances and good to go.
    Like the Microchip MPC9701 these are also linear. Your harsh environment is not a problem. Good for around 300 F.
    Industry standard? I use the LM34 in thermo wells at the plant where I work. One has an average temp 250 F. One degree resolution, no problems. We must be Non- standard.
    Lots of options.
  1. Digital clock thermometer Calendar PIC 16F628
    By valdirdf in forum Code Examples
    Last Post: - 31st May 2009, 01:52
  2. General Question About Multiple Interrupts
    By grzeh666 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2008, 17:09
  3. Serial Question + General Review
    By Freman in forum General
    Last Post: - 20th June 2008, 22:27
  4. General question about failure analysis
    Last Post: - 11th August 2006, 17:11
  5. 18B20 Thermometer Question
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 5th April 2006, 01:18
