Re-design your project.
Or DEBUG or SEROUT2Use SEROUT, right?
In your case there is not a benefit. If you were sending a longer distance or using HSEROUT then you would need it.And use a max232 (in this case what benefit to I have if the pic is already outputing RSR232 level signal?).
SEROUT -- N9600Whith what setting for SEROUT if not N9200?
SEROUT2 ---16468
DEBUGE --- DEFINE DEBUG_MODE 1
If you mean internal...Maybe.And can I or can I not use an external OSC?
Temperature change can cause the internal to vary. It may work on the bench but not in a finished application.
