Hi
I am trying to communicate between two 16F767 pics. The master PIC operates as an RGB mood lamp and sends a serial signal out to tell where in the program the master PIC is at, once the slave PIC is connected to the master PIC, the slave is supposed to receive the serial data and then continue at the same place wher the matsre is in terms of the RGB moodlamp effect. The code that follows has a glitch. If I take out the serial comms part of the code, the hardware PWM of the program works 100%, if I take out the hardware PWM part of the code, the serial part of the program works 100%, however, when they are put together as shown in the SLAVE's code below, the program does not work 100%. The RGB's leds light up randomly for a minute or so before the actual serial signal is recognised and then the program jumps to the corrrect place.
Device 16F767
CMCON = 7 ' Comparators Off
ADCON0 = 0 ' A/D Modules Off
ADCON1 = 7 ' All Digital Pins
Dim value As Byte
Dim red As Word 'Channel #1
Dim green As Word '#2
Dim blue As Word '#3
TRISC = %10000000
TRISA = 0
TRISB = 0 'CCP3 output
Dim redid As Byte
Dim orangeid As Byte
Dim yellowid As Byte
Dim greenid As Byte
Dim indigoid As Byte
Dim blueid As Byte
Dim violetid As Byte
Dim whiteid As Byte
Dim reddid As Byte
redid = 1
orangeid = 2
yellowid = 3
greenid = 4
indigoid = 5
blueid = 6
violetid = 7
whiteid = 8
reddid = 9
Declare RSIN_PIN PORTC.7
Declare RSIN_MODE 1
Declare RSIN_TIMEOUT 1000
Declare RSOUT_PIN PORTC.6
Declare RSOUT_MODE 1
Declare SERIAL_BAUD 2400
Declare RSOUT_PACE 100
DelayMS 500
blue = 0
green = 0
red = 0
value = 0
loop:
RSIn Wait("SLAVE"), value
If value = 0 Then
GoTo loop
Else
GoSub charin ' Get a character from serial input, if any
EndIf
charin:
If value = 1 Then
GoTo start1
ElseIf value = 2 Then
GoTo orange1
ElseIf value = 3 Then
GoTo yellow1
ElseIf value = 4 Then
GoTo greenn1
ElseIf value = 5 Then
GoTo indigo1
ElseIf value = 6 Then
GoTo bluee1
ElseIf value = 7 Then
GoTo violet1
ElseIf value = 8 Then
GoTo white1
ElseIf value = 9 Then
GoTo redd1
Else GoTo loop
EndIf
start1:
red = red + 1
GoSub LED_PWM
If red > 1000 Then
red = 1000
Else GoTo start1
DelayMS 1
EndIf
orange1:
green = green + 1
GoSub LED_PWM
If green > 1000 Then
green = 1000
red = 1000
Else GoTo orange1
DelayMS 1
End If
yellow1:
red = red - 1
DelayUS 13
GoSub LED_PWM
If red < 250 Then
red = 250
green = 1000
Else GoTo yellow1
DelayMS 1
EndIf
greenn1:
red = red - 1
DelayMS 4
GoSub LED_PWM
If red < 1 Then
red = 0
green = 1000
Else GoTo greenn1
DelayMS 1
EndIf
indigo1:
blue = blue + 1
GoSub LED_PWM
If blue > 1000 Then
blue = 1000
green = 1000
red = 0
Else GoTo indigo1
DelayMS 1
EndIf
bluee1:
green = green - 1
GoSub LED_PWM
If green < 1 Then
green = 0
blue = 1000
red = 0
Else GoTo bluee1
DelayMS 1
EndIf
violet1:
red = red + 1
GoSub LED_PWM
If red > 1000 Then
red = 1000
blue = 1000
green = 0
Else GoTo violet1
DelayMS 1
EndIf
white1:
green = green + 1
GoSub LED_PWM
green = 1000
red = 1000
blue = 1000
Else GoTo white1
DelayMS 1
EndIf
redd1:
green = green - 1
blue = blue - 1
GoSub LED_PWM
If green < 1 Then
red = 1000
blue = 0
green = 0
Else GoTo redd1
DelayMS 1
EndIf
GoTo orange1
'subroutine to utilise hardware PWM
LED_PWM:
CCP1CON = %00001100 'Mode select = PWM
CCP2CON = %00001100 'Mode select = PWM
CCP3CON = %00001100 'Mode select = PWM
PR2 = $FF
' Set TMR2 up for 1:16 prescale & turn it on
T2CON = %00001110 ' TMR2 ON 1:16 prescale
CCP1CON.4 = red.0 ' Setup 10-bit duty cycle as
CCP1CON.5 = red.1 ' a 10-bit word
CCPR1L = red >> 2
CCP2CON.4 = blue.0
CCP2CON.5 = blue.1
CCPR2L = blue >> 2
CCP3CON.4 = green.0
CCP3CON.5 = green.1
CCPR3L = green >> 2
DelayMS 50
Any ideas?
					 Master to slave 16F767
