pic to pic ir link versus wired link : help please anyone
Results 1 to 14 of 14
    xnihilo's Avatar
    xnihilo Guest
    It should work. But you probably need to invert it.
    On the transmit side, where it would previously turn the HPWM ON, make the pin LOW instead.
    For PWM OFF, set the pin HIGH, and forget the transistor.
    Added: And make sure the CCP module is turned OFF.
    Yes, turn it low instead of high because I have to pull low my receiver pic pin RA0 to trigger the int.
    But, and wouldn't it be better, I can also output a positive voltage pulse while the receiver pic is pulled to GND by a WPD resistor and PULSIN listens to a Low to HIGH transition: PULSIN porta.0,1,etcetera
    IF (a.0(0) == 0) THEN
        FOR i = 0 to 13                     'get a sequence of incoming 14 bits (WITHOUT their prefixes which are 600us pause)
            PULSIN PORTA.0,1,ir_pulse[i]    ' Read 14 low-going pulses on RA.4, see pbp manual
        NEXT i
        pin = 0                              ' Loop 14 times, record in 5us resolution pulse duration in the word variables array
    It would work too?
    BTW, why do I need to disable CCP module? It would prevent the output to work fine?
    And what's technicaly wrong with using a transistor???
    As long as MAX 25mA drive to the LED give you enough range... there's no 'real' need for the extra transistor.
    xnihilo's Avatar
    xnihilo Guest
    The IR led I use in the 'gun' module is boosted at 1A (!!!) so I have to use a HEXFET.
    Anyway, for the "Supplier module", it is only to send a 14bits message and as I wrote above, to avaoid cheating, I really need to use a wired link instead of IR link. So I have to avoid using IR link.
    Except for the 'heating/burning' pads...
    xnihilo's Avatar
    xnihilo Guest
    gimme a break willya
    Quote Originally Posted by xnihilo View Post
    Yes, as long as the CCP module is ON, it has control of the CCP1 pin.
    And what's technically wrong with using a transistor???
    Nothing really. Just extra parts that don't add any functionality.
    But after thinking a little more about it ...
    With people that are running and jumping with nylon backpacks while wearing rubber soled shoes ... If the first contact between 2 of them is going to be the connection to deliver a health pack? I think extra ESD protection on those pins would be the biggest concern.
    xnihilo's Avatar
    xnihilo Guest
    jeeze... i didn't think about that.
    the pics don't have some esd protection like the eeproms (24lc08 seem to have that)?
    How can i prevent an esd? using a capacitor?
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 06:09
  3. SPI configuration PIC versus Atmel
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 10th July 2007, 19:17
  4. Need help building a simple IR learning remote with a PIC
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 20th April 2006, 22:22
