I Want To Build Propic 2 Gold And Have Hex File For The 12c508 That Was Used, But I Have 12f675 And Want To Know Whether Recombiling This Code For 12f675 Will Make The Code Work Flawlessly?
If you have the source code for the 12C508, you will need to modify it a little bit as the 12F675 have ADCs and comparator that 12C508 don't. If you don't disable the extra feature, you will run into problem.
For the Config Fuses, see this one
Presetting Configuration Fuses (PIC Defines) into your Program
POST #1 and POST #5 cover everything you need to know.
Not a bad idea to have a look at the following too.
PortA Doesn't Work & Common 8-Bit PIC® Microcontroller I/O Pin Issues (TB3009)
HTH
