Ok, so further testing - this time using Audacity to record the waveforms as it gives me more freedom to scroll back and forth - has resulted in the following 3 waveforms: http://img527.imageshack.us/my.php?i...8222006dl4.png
I'm going to opt to completely ignore the first transmission sequence as the start of it is a little messed up and target the second transmission sequence (I pushed the button as fast as I could, I always got 2 or more sequences).
So the following code is what I've got (haven't run it yet).
Does it look right?
I was playing around with it before as '1's instead of '0's in pulsin but it was picking up the block of 0's not the block of 1's. (If that makes any sense)
I've decided to chop the data comming up as
ADDRESS-DATA-S
1111000100110101-11000000-0
1111000100110101-00110000-0
1111000100110101-00000011-0
Following the encoder's specs this is actually
110F01FF1000S
110F01FF0100S
110F01FF0001S
F = Floating
S = Sync
Further reading of the specs - there'll be 4 sequences. Seeing as the first of the sequence is trashed, I just need to record and compare the other 3
Code:' Configure the FUSE options for the compiler @ device pic16F628A, hs_osc, wdt_off, pwrt_on, lvp_off, protect_off, bod_on, cpd_off, pwrt_off, mclr_off ' Running a 4Mhz clock DEFINE OSC 20 DEFINE PULSIN_MAX 3000 ' Setup the USART DEFINE HSER_RCSTA 90h ' Receive register to receiver enabled DEFINE HSER_TXSTA 20h ' Transmit register to transmitter enabled DEFINE HSER_BAUD 9600 ' Set baud rate CMCON = 7 ALL_DIGITAL RFIN VAR PORTB.7 INPUT RFIN PBITS VAR BYTE[17] ' The bits we've read RAW VAR BYTE ' The raw pulsin value ADDRESS VAR WORD ' Storage for the address DBYTE VAR BYTE ' Storage for the data X VAR BYTE Y VAR BYTE GET_ADD: ADDRESS = 0 : RAW = 0 : DBYTE = 0 GET_PULSE: ' Count 4 long pulses. FOR x = 0 TO 3 PULSIN RFIN, 0, RAW if RAW < 220 OR RAW > 230 THEN GET_PULSE NEXT X ' Count 3 short pulse. FOR X = 0 to 2 PULSIN RFIN, 0, RAW IF RAW < 70 OR RAW > 80 THEN GET_PULSE NEXT X ' Read 9 address bits and 8 data bits FOR X = 0 TO 16 PULSIN RFIN, 0, RAW PBITS[x] = NCD RAW NEXT X ' Read a sync bit PULSIN RFIN, 0, RAW IF RAW < 70 OR RAW > 80 THEN GET_PULSE ADDRESS = 511 ' Maxmimum known ID FOR X = 0 to 8 IF PBITS[x] > 7 THEN ADDRESS.0[X] = 0 NEXT X DBYTE = 255 ' Maximum known data value Y=0 FOR X = 9 TO 16 IF PBITS[X] > 7 THEN DBYTE.0[Y] = 0 Y = Y + 1 NEXT X IF ADDRESS > 0 THEN WRITE 1, ADDRESS.LowByte WRITE 2, ADDRESS.HighByte Write 3, DBYTE HSEROUT ["ADD = ",IBIN9 ADDRESS," : ",IDEC ADDRESS,13,10] HSEROUT ["DAT = ",IBIN8 DBYTE," : ",IDEC DBYTE,13,10] ENDIF GOTO GET_ADD END
