Pulse Decoding
Results 1 to 13 of 13
Thread: Pulse Decoding
    May 2008
    Default Pulse Decoding
    G'day there.
    I've still trying to replace a pic on a board. I've got a whole new approach that I'm working on.
    I want to decode the pulses received from the RF receiver.
    I don't have a CRO or anything useful like that, but can anyone give me any idea how I might have the pic read these pulses and store details about them in eeprom?
    Or perhaps how I can read and compare these pulses to a list of knowns? (I have the specs on the transmitter, but not the receiver)
    EDIT -
    Ok, I've hacked myself up a cheap scope (sound card + voltage divider )
    UP: http://img443.imageshack.us/my.php?i...8235605zw2.png
    Stop: http://img47.imageshack.us/my.php?im...8235856ae3.png
    Down: http://img47.imageshack.us/my.php?im...8000034iy4.png
    So um... anyone know how I might go about reading these signals with a PIC/picbasic?
    Dec 2005
    Is that all there is to the code? Frequently there is a wide pulse/space pair that acts as a Start of Frame marker.
    What type of transmitter? receiver? ASK vs. FSK and whether or not there is a carrier detect signal makes a huge difference in how you detect the start of a transmission.
    The codes themselves are quite simple, containing 24 data bits (the last pulse is an End of Frame marker). Each bit has a fixed period (~0.67mS) and the width of the pulse determines 1 vs. 0. I would assign 1 to the wider pulses and just use PulsIn to capture them.
    May 2008
    I don't honestly know what type of receiver.
    This is the transmitter chip: http://pdf1.alldatasheet.com/datashe...TC/PT2264.html
    it's running at around 12v and has a 1.5 mOhm resistor on it's osc.
    This is what I've worked out with the scope program - Give or take
    600u whole bit.
    1: 450 high, 150 low
    0: 150 high, 450 low
    UP: 11110001001101011100000
    Stop: 11110001001101001100000
    Down: 11110001001101100000011
    Dec 2005
    That's not the transmitter. It's just the encoder chip.
    Bruce Reynolds has posted code for decoding these signals. I don't recall whether it was this specific encoder or a Holtek encoder which works the same way.
    There is no Start of Frame so you have to detect the long silence which occurs between codes and capture/decode the 2nd or later copy. A search here will turn up Bruce's code. Or, he's likely to jump in and point you to it.
    I posted a simple example for decoding a Holtek 8-bit encoder here;
    http://www.picbasic.co.uk/forum/showthread.php?t=6581
    The Holtek 640 encoder is similar to the one you have with 2 pulses per bit, but the Holtek
    packets are 10-bit address with 8-bit data. It should at least give you a good base to start
    from.
    Here's a simple chopped-down version example of decoding a Holtek HT12E.
    DEFINE OSC 20            ' 20MHz xtal
    DEFINE PULSIN_MAX 3000  ' Set MAX wait for pulses to speed-up response time
    PBIT        VAR BYTE[12]' Pulse-in values after NCD
    NUMS        VAR WORD    ' RAW pulsin value
    ADDRESS     VAR BYTE    ' address
    DBYTE       VAR BYTE    ' data byte
    X           VAR BYTE    ' GP loop counter
    Y           VAR BYTE    ' GP variable
    DIN         VAR PORTB.0 ' Data input direct from HT12E encoder IC
    TRISB.0=1
    GET_ADD:
        ADDRESS=0 : DBYTE=0 : NUMS=0
    GET_P:
        PULSIN DIN,1,NUMS
        IF NUMS < 100 THEN GET_P  '
                                  ' if sync pulse is less than 200uS restart.
        FOR X = 0 TO 11           ' read 12 pulses
         PULSIN DIN,1,NUMS        '
         PBIT[X] = NCD NUMS       ' convert high-bit-set
        NEXT X                    ' loop until done
        ' Get address
        ADDRESS=$FF               ' start with all 1's and find each 0
        FOR X = 0 TO 7            ' PBIT bytes 0 to 7 = address
         IF PBIT[X] >7 THEN ADDRESS.0[X] = 0 ' If NCD val > 7 it's a 0
        NEXT X
        ' Get data
        Y=0
        DBYTE=$0F           ' start with all 1's and find each 0
        FOR X = 8 TO 11     ' PBIT bytes 8 to 11 = encoder 4-bit data
         IF PBIT[X] >7 THEN DBYTE.0[Y]=0' DBYTE bits 0 to 3 are our data-bits
         Y=Y+1
        NEXT X
        ' show results
        HSEROUT ["ADD = ",IBIN8 ADDRESS," : ",IDEC ADDRESS,13,10]
        HSEROUT ["DAT = ",IBIN4 DBYTE," : ",IDEC DBYTE,13,10]
        GOTO GET_ADD
    The .JPG file attached shows a logic analyzer capture of the HT12E output.
    Serial terminal result;
    ADD = %10111011 : #187
    DAT = %1011 : #11
    This matches the address & data I had set on the HT12E encoder when the program ran.
    You can change the address & data, press /TE, and watch the results on-screen.
    Note: This code example is a chopped version with only a single-pass. In most
    applications you will want to do 2 or 3 passes, then verify multiple address/data packets
    before you change a decoders outputs. Otherwise it's prone to errors.
    This version is suceptible to noise. That's why it was tested with a direct connection from
    encoder to PIC input. This remains stable. The data output of an RF receiver however, is a
    diferent story. You'll se a TON of noise pulses there.
    The tricky part is working in the multi-pass & verify routines. That part I can't share...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    May 2008
    Thanks for the information Bruce.
    My input signal appears to be high and fairly noisy with pulses low - I really need a real scope
    If I read the code you provided correctly, it shouldn't reach GOTO GET_ADD without receiving a full pulse (or at least a full initial pulse)
    Mine's running all the way through without thinking about it, even with a resistor to gnd and no actual signal.
    I don't have a uart hooked up to this board at the moment so I'm just storing the values in eeprom - they're all showing up as 0's
    - Edit
    Oh dear, spoze if it wasn't 3 am and I'd had some coffee I would have done some thinking
    1) 4 mhz clock (getting 20 mhz crystals tomorrow, ran out)
    2) This is probably a one off - so at the very least I can look for 4 high pulses at the start, if not look specifically for more components of the bitstream
    I'll go to bed now and resume banging head on desk tomorrow.
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 3
    Last Post: - 13th September 2008, 18:40
  4. Decoding an incoming infrared signal: need advice
    Last Post: - 9th May 2008, 17:28
  5. Pulse Frequency Multiplication
    Last Post: - 21st August 2005, 11:39
