from interrupt to other labels
Results 1 to 5 of 5
    Careful when using nested subs... may run into stack overflow sooner than you may think.
    your right. i did run into a stack overflow problem when i was simulating the code. i tried to make my program more modular with nested subs but i guess the stack can only be 3 gosubs deep, anything more will give me a stack overflow problem
    i will put my routines in loop1 and loop2 inside the interrupt. i think that will work and i won't run into an overflow problem.
    thank you mr. e
    What would loop1 and loop2 do? And what will trigger then int?
    Like Steve said, might be a better way.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 20:54
  4. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
