from interrupt to other labels
Results 1 to 5 of 5
    Look at the interrupt as a subroutine. What ever you have triggering the interrupt will cause this special sub to run. Then as in a gosub, when it is finished the resume resumes...
    So what ever lable1 and label2 are, do these inside of the interrupt.
    Not a good idea to break out of an interrupt. Need to finish it and enable/resume.
    Careful when using nested subs... may run into stack overflow sooner than you may think.
    You should rethink of your whole program. Maybe INTs are not needed at all. General rules, keep ISR short, set variables and/flags in, once you get out, your main program will check those variables and branch to the according routines.
    If you plan to use gosub/goto in your ISR, the routine you will jump to have to be within the DISABLE/ENABLE code section.
    your right. i did run into a stack overflow problem when i was simulating the code. i tried to make my program more modular with nested subs but i guess the stack can only be 3 gosubs deep, anything more will give me a stack overflow problem
    i will put my routines in loop1 and loop2 inside the interrupt. i think that will work and i won't run into an overflow problem.
    thank you mr. e
    What would loop1 and loop2 do? And what will trigger then int?
    Like Steve said, might be a better way.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 19:54
  4. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
    Last Post: - 6th March 2005, 01:07
